Uberdata and P13?
Old May 10, 2005 | 08:07 AM
SIckH22Atch's Avatar
Default Uberdata and P13?
I have a chipped jdm p13... can uberdata be run on the jdm p13? I have a feeling the answer is no.
ok, just looked on the Uberdata webpage (http://uberdata.pgmfi.org) and it says to use any civic/integra ecu... doesn't say anything about prelude ecus.
Old May 10, 2005 | 11:08 AM
sleeper95Lude's Avatar
Default Re: Uberdata and P13? (SIckH22Atch)
Won't work. The civic/teg ECUs use a totally different type of program from the 'lude. The P12/13/14 family is completely different from the P28/30/72. As far as I can tell, the Prelude ECUs don't even have static fuel and ignition maps like the teg ones do.
You can get a P72 though, and use Uberdata to tune it to run the H22, or whatever engine you've got.
Old May 10, 2005 | 11:39 AM
IHateJDM's Avatar
Default Re: Uberdata and P13? (sleeper95Lude)
I heard that uberdata recently (a few weeks ago) began to support the p13. I know there are roms out there for it.
Old May 10, 2005 | 11:47 AM
from what I have been reading, it says that the way that it calculates fuel is different and that is the reason why. I haven't seen anything saying that it will work on the p13s.
Old May 10, 2005 | 11:49 AM
Under_Pressure's Avatar
Default Re: Uberdata and P13? (IHateJDM)
The only thing that they need to break is the code for the dam fuel maps equation. It’s completely different of that of a p28, p72. The p13 is more complicated and looks to be an awesome ecu to tune when the code is broken. Till then find your self a p28
Old May 10, 2005 | 02:49 PM
Default Re: Uberdata and P13? (92h22alude)
p72 for me just in case I do want to use the butterflies
Old May 10, 2005 | 06:03 PM
If you get a msd window switch you can still use your butterflies just find out what rpm you want it to open, get the pill and hook it up.
Old May 10, 2005 | 06:07 PM
SKDRCR's Avatar
Whoever brakes the code, I'll send them a case of ,
not that they won't be able to buy one anyway
Old May 10, 2005 | 06:09 PM
IHateJDM's Avatar
Default Re: Uberdata and P13? (SKDRCR)
You can get a p28 to control secondaries. ask turbogixxer, he knows how.
Old May 10, 2005 | 06:15 PM
yOnKiNaToR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">I heard that uberdata recently (a few weeks ago) began to support the p13. I know there are roms out there for it.</TD></TR></TABLE>
are you serious? that would be awesome! i have to check the uberdata forums now.
Old May 10, 2005 | 06:48 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">Whoever brakes the code, I'll send them a case of ,
not that they won't be able to buy one anyway </TD></TR></TABLE>
Crome has P13 support but I have never tried it, yet. Send Mind-eraser a case
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">You can get a p28 to control secondaries. ask turbogixxer, he knows how.</TD></TR></TABLE>
It is no sercet.
http://www.pgmfi.org/twiki/bin...ToP28
Happy soldering
Note: p05/06/28 ECUs share the same board(s).
Old May 10, 2005 | 08:55 PM
SKDRCR's Avatar
Default Re: Uberdata and P13? (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Crome has P13 support but I have never tried it, yet. Send Mind-eraser a case </TD></TR></TABLE>
Yes, I've heard this, but how well can you really tune it with the Crome System?
Does it have all the other options like HOndata and Uberdata have?
Old May 12, 2005 | 11:58 PM
MindEracer's Avatar
Does it have all the other options like HOndata and Uberdata have?</TD></TR></TABLE>
Right now you can only tune your vtec X over, your target idle etc....
You can also tune your ignition maps, FTL is in the works as well as Datalogging and fuel will be figured out someday
Old May 13, 2005 | 05:31 AM
IHateJDM's Avatar
Default Re: Uberdata and P13? (MindEracer)
could it be? a disable egr option? damn i need a chip burner now.
Old May 13, 2005 | 09:02 AM
This would be good and just in time because last night I instaled my turbo no need for me to buy a p28. Plz plz brake the code in time before i get a p28.
Old May 13, 2005 | 09:11 AM
Nature's Renewal's Avatar
I just went from the crx scene to the prelude. This would be interesting because I've used turboedit before and have a burner...bump
Old May 13, 2005 | 09:38 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindEracer &raquo;</TD></TR><TR><TD CLASS="quote">Right now you can only tune your vtec X over, your target idle etc....
Cromescreencap
You can also tune your ignition maps, FTL is in the works as well as Datalogging and fuel will be figured out someday </TD></TR></TABLE>
Wow, that's very interesting . . . . too bad no fuel map adjustment yet, but it sounds like things are coming along.
And I assume you'd need an OBDI P13?
Old May 13, 2005 | 09:40 AM
IHateJDM's Avatar
Default Re: Uberdata and P13? (Daemione)
yep, obd1 if you're gonna chip it. the p13 is really easy to chip too.
Old May 13, 2005 | 11:11 AM
SKDRCR's Avatar
Very nice
Is the example setting for stock vtec cams?
Old May 23, 2005 | 04:44 PM
greatbiggiants's Avatar
Want to know BUMP
jdmludesi
Jul 15, 2010 08:50 PM
Nixon29
Aug 23, 2007 04:33 PM
tegman85
Sep 26, 2006 09:57 PM
greenli0n25
May 4, 2003 08:21 PM
turboex
Jul 31, 2002 07:45 AM
