head swap = map sensor error??? HELP!
Old May 9, 2005 | 09:19 AM
DarkBB4's Avatar
Default head swap = map sensor error??? HELP!
Just swapped the head on my brothers h22a to a port and polished head.
Got everything hooked up and the ecu is throwing a map sensor error! I checked the map sensor and even tried replacing it with 2 other sensors. Still throwing the code. I could have the wrong plug in, but im pretty sure that it is right. The h22 is in an integra, running a jdm p13 ecu. Let me know if u have any suggestions! Thanks a lot
Old May 9, 2005 | 11:03 PM
PrettyLude's Avatar
u have the right plug going into the harness? the tps and map use the same kind of plug to them
Old May 9, 2005 | 11:06 PM
shdriver99's Avatar
Default Re: (PrettyLude)
Most likely have your cam timing off bleeding off compression back into the intake manifold. Do you hear an air leak at idle? I had the same problem when I first put my built head back on!
Randyb18
Aug 9, 2015 03:07 PM
D15JDMARIO
Feb 18, 2007 01:52 AM
jaredvabeach
Jan 30, 2007 01:44 AM
justinb
Jun 2, 2005 03:39 PM
