Causes of backfire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveobb4 »</TD></TR><TR><TD CLASS="quote">Raw fuel contacting your exhaust and exploding. ( correct me if im wrong).</TD></TR></TABLE>
ur correct. if you are running rich as hell, it will do that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote"> can you shoot a fireball? </TD></TR></TABLE>
I can shoot a fireball, but only if I get two purple upgrades and one of the blue flashing ones..
hmm... do you mean accidentally or do you want to shoot a fireball?
I've heard of a few exhausts that can let that kind of thing happen, but no idea if it's doable in a tercel (not ripping on toyos, just don't know much about them) but i think that involves a race cat or test pipe and a bit of luck.
if you want to shoot fireballs (sigh) look on ebay, there are kits you can get.. they're "for show purposes" only, but basically it cuts out your spark for a second so there's a lot of fuel in the exhaust, then there's a spark plug at the end of your exhaust pipe, so it burns the fuel...
From: united states of mexico and yes ladies i am, available
my car was running rich when i had CEL and a gutted and i would just drive it hard and swich from 1st to 2nd and boom! my friend that was behind me said it was like a matches but not a fire ball and the car always smelled like gas
my mileage is bad. my car doesn't smell like gas though. it's not bad at all until higher rpm's. you don't want to be behind me when I get on it though, i leave a small cloud of fuel and other misc **** in the air behind me, and yeah i get backfires between every shift.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy »</TD></TR><TR><TD CLASS="quote">ur correct. if you are running rich as hell, it will do that.</TD></TR></TABLE>
what does mean when ur running rich? good thing? i'm noob
first off, thank you for using the search function
running rich means there are more parts fuel than air inside the combustion chamber than normal/necessary. Its not a good thing, but its not bad unless you are running insanely rich. Running too rich can be VERY bad and can ruin the motor. By running a motor too rich, you can wash the oil off the cylinder walls and the rings will eat up the cylinder walls and in the end you will loose compression.
asergioc
Aug 23, 2007 12:06 PM
