Code 3
Old May 8, 2005 | 09:26 AM
DarkBB4's Avatar
Default Code 3
Map sensor
Will any other sensor cause this cel, because we cant figure it out... We have swapped maps, and etc..
WE NEED HELP..
Old May 8, 2005 | 09:32 AM
sharkcohen's Avatar
Default Re: Code 3 (DarkBB4)
No, only the MAP sensor. If you've tried a known good sensor, it's either the wiring or the ECU.
Old May 8, 2005 | 09:38 AM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">Map sensor
WE NEED HELP..</TD></TR></TABLE>
Code for MAP sensor doesn't always mean the MAP sensor itself is defective. Check the wires for short.
Old May 8, 2005 | 10:15 AM
DarkBB4's Avatar
Default Re: Code 3 (xbn83)
hmm... we swapped the head, but used the same intakem anifold and now its all fkd up...
how can we dianose this
It had a VAFC, then it was removed and ive checked the "pressure" signal over and over again.. and the connection is GREAT with a thicker gauge wire as a extenstion
the map hooks up to a line that hooks up to the little NIPPLE on teh intakke manfild.. does it matter where on the im?
Old May 8, 2005 | 02:14 PM
kulrevon's Avatar
If it had a v-afc in it before and you pulled it out that is your problem. Follow the old vafc harness to the ecu harness. You have to splice the map wires back together.
its either d17 white /blue or d21 blue/white they spliced
hope this helps
Old May 8, 2005 | 04:37 PM
PrettyLude's Avatar
make sure you plug the right harness to it, cuz the map and tps sensor has the same plugs, sometimes people put the wrong plugs and the wrong places
Old May 8, 2005 | 05:29 PM
DarkBB4's Avatar
Default Re: (PrettyLude)
wheres the tps sensor and what plug is it
Ive double and triple checked the wireing,... redid it like 10 times
Old May 8, 2005 | 06:09 PM
PrettyLude's Avatar
tps is on the side of the throttle body
Old May 8, 2005 | 06:13 PM
DarkBB4's Avatar
hmm... u think colors would matter? of the wires.
how can i tell the tps from map anwyays?
would i get a tps cel if the tps was not plugged in?
also, when we unplug the map compeltely, the car rpms fall, so u thiik it STILL has to do with wiring?
Old May 8, 2005 | 09:01 PM
lakerschamp2000's Avatar
your vtec controller is bad.
FSS13foxtrot
Jan 20, 2008 06:23 AM
Sci_v_icI
Apr 5, 2006 10:44 AM
