5th Gen H22A4 Tranny swap
Location: united states of mexico and yes ladies i am, available
Re: 5th Gen H22A4 Tranny swap (apgarabu)
try to get a lsd as well i love it soooooo much when i did my 5speed swap the tranny i found had a quaife lsd in it
A 5spd swap can cost anywhere from $2000+ depending on where you get your parts and if you install everything yourself.....If you need a 5spd cluster, I have one for sale
Re: 5th Gen H22A4 Tranny swap (mraza)
Here's a list of parts you'll need
-5spd Tranny
-Tranny mounts
-Flywheel w/bolts
-Clutch w/bolts
-Master cylinder
-Slave cyclinder
-Clutch Damper
-VSS (Vehicle Speed Sensor)
-Reverse switch
-Hydraulic lines
-Pedal Assembly
-Shifter Assembly
-Shift linkage
-5spd ECU
-5spd Intermediate Shaft
-5spd Cluster
-Helms manual (would make the job alot easier)
-Assorted nuts and Cotter pins
-5spd Tranny
-Tranny mounts
-Flywheel w/bolts
-Clutch w/bolts
-Master cylinder
-Slave cyclinder
-Clutch Damper
-Reverse switch
-Hydraulic lines
-Pedal Assembly
-Shifter Assembly
-Shift linkage
-5spd ECU
-5spd Cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">A 5spd swap can cost anywhere from $2000+ depending on where you get your parts and if you install everything yourself.....If you need a 5spd cluster, I have one for sale</TD></TR></TABLE>
yeah if i instaled every thing myself it would have been about $2600
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mraza »</TD></TR><TR><TD CLASS="quote">I need a new tranny aswell... just wondering what does a tranny with a lsd do???</TD></TR></TABLE>
it gives both wheels equal power it helps you to drag race and and road race or auto X it helps you come out of a corner fatser and you get to leave 2 black lines when you peel out
prelude1897- good list
Re: 5th Gen H22A4 Tranny swap (raylude)
dude, did you buy that swap with the lsd from a girl in Columbus??? I was going to buy that tranny swap, and you stole it out from under me. i was so pissed!
Lo0z3rCIVICBoi
12-15-2006 09:38 PM
