Code 9, CYP - cylinder sensor
Old May 10, 2005 | 10:30 PM
mikeds122's Avatar
Default Code 9, CYP - cylinder sensor
My jdm h22 is throwing a code 9 (CYP cylinder sensor). It started after accelerating hard from a stop (I believe after a bit of wheel hop going into 2nd). Anyway, my distributor recently was replaced and my mechanic wired an external coil because it was too hard to find a cap for an internal coil. Not sure if that has anything to do with it, but is this dangerous? Car feels exactly the same...
Old May 10, 2005 | 11:32 PM
bad-monkey's Avatar
the CYP sensor is a sensor within the distributor that i think is magnetic and sends the signal to the ECU about where cyl 1 is.
the first thing to do is to get a multimeter and check resistance on the 4 prong. it's hard to describe, and it'd be best if you had a helms to explain it, but i'm guessing it the cute wiring of the distributor.
Old May 11, 2005 | 03:39 AM
01 LudeDude's Avatar
Default Re: (bad-monkey)
I used to get that code when I had idle problems. If the revs dropped down to 200-300, it would kick that code. Adjusted idle and never got it again.
Old May 11, 2005 | 01:20 PM
mikeds122's Avatar
Default Re: (01 LudeDude)
Is it going to be dangerous if i drive it? Don't have time to look at it right now
kirbyman
Oct 20, 2024 07:35 PM
Jimster480
Dec 23, 2009 03:14 PM
TyeJ23
Nov 7, 2005 01:42 PM
RaIn
Apr 20, 2003 08:05 PM
H22CIVIC
Jul 2, 2001 11:19 AM
