speaker fitment
Old May 5, 2005 | 04:13 PM
diluted's Avatar
Default speaker fitment
sup guys, i just bought some orion p6.2 comps for my prelude. i was wondering if i could fit the speakers since they have a depth of 3 inches. also where would i mount the tweeter? if i do put them in the stock lcation location, what do i do about the crossovers? thanks.
Old May 5, 2005 | 05:40 PM
fenominal's Avatar
Default Re: speaker fitment (diluted)
4th gen or 5th gen?
if it's a 4th, the stock tweeters are up front, in each corner of the dash. It's fairly easy to pull the cover off. my crossover is behind my head unit...
if it's a 5th...I wouldn't know.
Old May 5, 2005 | 07:28 PM
01 LudeDude's Avatar
Default Re: speaker fitment (fenominal)
5th gen will probably need some small spacers to accommodate the magnet depth, and the tweets can go in the factory location, top of door panel. You could put the x-overs in the doors, or under the dash somewhere.
Old May 6, 2005 | 12:13 AM
diluted's Avatar
its a 4th gen btw, i guess i thought the speakers connected to the crossover too. is it only the tweeters that connect to the crossovers? how big should the spacers be? thanks guys.
Old May 6, 2005 | 01:29 AM
ludelvr's Avatar
The depth may be a problem. You may need to buy some spacers for them.
Old May 6, 2005 | 03:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diluted &raquo;</TD></TR><TR><TD CLASS="quote"> is it only the tweeters that connect to the crossovers? how big should the spacers be?</TD></TR></TABLE>
The spacers will be about .5" or so, not sure about 4th gens. Both speakers will connect to the crossover. If you plan to put them inside the door, then there is no problem. If you want to put them under the dash, then you will need to run an extra set of speaker wire into each door.
Old May 6, 2005 | 04:12 AM
Jesus_FR's Avatar
Put the crossovers in the door, below the arm rest, there is plenty of space there. The speakers and tweeters both connect to them, thus you'll have to run the tweeter cable through the door into the dash.
Old May 8, 2005 | 06:19 PM
diluted's Avatar
Default Re: speaker fitment (Jesus_FR)
dang what should i do about the spacer thing. should i make my own or do they sell premade ones?? the wiring is all crazy right now. i cant put the crossovers under my door cuz there seems to be no space, and even if i did, the tweets are on my dash, but i can't find a useful hole for my doors. theres like one hole, but i can't find it through my dash.
Old May 8, 2005 | 06:39 PM
ludelvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diluted &raquo;</TD></TR><TR><TD CLASS="quote">dang what should i do about the spacer thing. should i make my own or do they sell premade ones?? the wiring is all crazy right now. i cant put the crossovers under my door cuz there seems to be no space, and even if i did, the tweets are on my dash, but i can't find a useful hole for my doors. theres like one hole, but i can't find it through my dash.</TD></TR></TABLE>
you can buy some and I don't think they're that much, however they'll prolly be some generic one that you'll need to modify. Making them is pretty easy too. Two potential problems is that either 1. you use a spacer that is too thick and the panel won't sit in all the way and 2. if you use a spacer that still doesn't provide you enough clearance and the window when rolled down may hit the speaker magnet. Just make sure you get your measurements right
Old May 8, 2005 | 07:47 PM
diluted's Avatar
Default Re: speaker fitment (ludelvr)
do any of u guys know the total clearance without hitting the window? the speakers i have are about 3.5" with the mounting bracket.
Old May 8, 2005 | 08:18 PM
veganej's Avatar
not too sure on that, id use washers if u cant find any spacers.
rocket30004
Mar 6, 2007 03:35 PM
Jordans95si
Oct 16, 2005 03:21 PM
JLockheed
Feb 13, 2004 11:25 PM
