Difference between oil pressure/level
Old May 11, 2005 | 11:49 AM
RemerLex11's Avatar
Default Difference between oil pressure/level
what exactly is the difference between oil pressure and oil level?
Old May 11, 2005 | 12:31 PM
Eddiebx's Avatar
oil pressure is how much pressure the pump is pumping the oil through ur motor at. and oil level is how much oil u phsycially have in ur oil pan.
Old May 11, 2005 | 04:01 PM
RemerLex11's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">oil pressure is how much pressure the pump is pumping the oil through ur motor at. and oil level is how much oil u phsycially have in ur oil pan.</TD></TR></TABLE>
so if I were short around 1/2 - 1 quarts of oil, and my oil pressure was at normal psi, would it be okay to drive w/ that amount of oil?
Old May 11, 2005 | 05:30 PM
RemerLex11's Avatar
Default Re: (Matt5745767)
bump for the night and waiting for the experts
Old May 11, 2005 | 05:35 PM
tarheelsoldier's Avatar
yes its fine to drive on. just fill it up as soon as you can. say next day or two. my brother ran around on 4 quarts of oil in his eclipse for 3-4 months. so if that motor can survive then a prelude motor will do fine. he didnt fill up the oil either and it turned a lovely jet black and had about 2.5-3.5 qts left.
Old May 12, 2005 | 06:14 AM
RemerLex11's Avatar
Default Re: (tarheelsoldier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tarheelsoldier &raquo;</TD></TR><TR><TD CLASS="quote">yes its fine to drive on. just fill it up as soon as you can. say next day or two. my brother ran around on 4 quarts of oil in his eclipse for 3-4 months. so if that motor can survive then a prelude motor will do fine. he didnt fill up the oil either and it turned a lovely jet black and had about 2.5-3.5 qts left.</TD></TR></TABLE>
but when I fill it up to the second dot, about 1/2 a quart always leaks out and stays at that level w/out leaking anymore out.
Old May 14, 2005 | 09:31 AM
Eddiebx's Avatar
whree does it leak out from?
Old May 14, 2005 | 12:20 PM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">whree does it leak out from?</TD></TR></TABLE>
from the top of the oil pan, and there's a stain around the oil cap (even though its on as tightly as it can be), and in the top right corner (to the right beside VTEC) where that plug is.
Old May 14, 2005 | 12:39 PM
92hondalude's Avatar
you need to get an oil pan gasket.
Old May 14, 2005 | 01:36 PM
Eddiebx's Avatar
yeah sounds like u got some busted gaskets, and or orings and seals, go and replace everything u find leakign and you should be good
Old May 15, 2005 | 02:35 PM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">yeah sounds like u got some busted gaskets, and or orings and seals, go and replace everything u find leakign and you should be good</TD></TR></TABLE>
yeah that's what I thought, but the weird thing is that when I'm about a 1/2 a quart low, it doesnt leak at all.
an2ny888
May 6, 2013 10:31 AM
Takumi Fujiwara
Jul 22, 2006 04:13 PM
vtec.dc2
Mar 9, 2004 04:41 AM
vtec.dc2
Feb 1, 2004 10:49 AM
