help!! problem after testing compression
Old Jun 13, 2006 | 06:58 PM
spliffsta2's Avatar
Default help!! problem after testing compression
well, I performed the compression test today for the first time using a write-up on prelude-power.com... everything was going fine and i just finished checking cylinder 1 (compression was ~240)... so i went to screw the spark plug back in the cylinder and attach the spark plug wire back on the spark plug BUT the wire wouldn't go in all the way down the cylinder (stopped at about midpoint)... so i unscrewed the spark plug and found that the side electrode was crushed into the center electrode...
when i checked inside the cylinder with a flashlight... the hole the sparkplug is supposed to screw into is pushed waayy up (picture 2)... the first picture below is of cylinder 2 which is what it should look like....
anyone had any experience with this??? or kno if this is fixable w/o getting a new head??
CYLINDER 2: (normal)
CYLINDER 1 (picture 2)
Old Jun 13, 2006 | 07:26 PM
sharkcohen's Avatar
Default Re: help!! problem after testing compression (spliffsta2)
That's the adapter for your compression tester stuck in there. Put some locktite on the threads at the end of the compression tester hose, screw it back into that, give it a minute, then screw it out as one piece.
Old Jun 13, 2006 | 08:20 PM
spliffsta2's Avatar
Default Re: help!! problem after testing compression (sharkcohen)
HOLY CRAP... i was so shocked that i bust something upward that i didnt even notice that the adapter was missing off the gauge hose...
u da man cohen!! MADD PROPS FOR THIS!
Old Jun 13, 2006 | 08:35 PM
sharkcohen's Avatar
Old Jun 14, 2006 | 04:54 AM
flyrod's Avatar
That is pretty good penmanship on your pictures. Did you write that with a mouse?
Old Jun 14, 2006 | 06:28 AM
Pullig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spliffsta2 &raquo;</TD></TR><TR><TD CLASS="quote">HOLY CRAP... i was so shocked that i bust something upward that i didnt even notice that the adapter was missing off the gauge hose...
u da man cohen!! MADD PROPS FOR THIS! </TD></TR></TABLE>
PLEASE STEP AWAY FROM the PRELUDE WITH TOOLS .... poor car
Old Jun 14, 2006 | 06:35 AM
esedulerp5tenin's Avatar
Default Re: help!! problem after testing compression (Pullig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">
PLEASE STEP AWAY FROM the PRELUDE WITH TOOLS .... poor car</TD></TR></TABLE>
hahahahhaha
TravisBiggie
Sep 29, 2013 06:33 PM
dizzyroc88
Sep 10, 2010 03:22 PM
thunderboy
Apr 24, 2010 08:39 AM
B18CivicHatch
Aug 24, 2007 12:13 AM
killalude03
May 14, 2006 06:42 PM
