my first post and question
Old Jun 13, 2006 | 09:33 AM
f155mph's Avatar
Default my first post and question
Hello All,
My first post here and I hope someone may be able to help me.
I got a 92 Prelude Si 5 spd. Recently I notice the car is having speedometer issue. Sometime the speedometer will not work and just show 0. It happens randomly. One time it did this for about 2 mins and the check engine light came on afterward. I got to where i was going and when I return and started the car, everything was fine again with no engine light.
So I would like to know might be the cause of the problem?
Thanks!
Old Jun 13, 2006 | 09:34 AM
nismo350z's Avatar
Default Re: my first post and question (f155mph)
do you have aftermarket gauges?
Old Jun 13, 2006 | 09:36 AM
monalisa overdrive's Avatar
Default Re: my first post and question (nismo350z)
could be the alternator going out, i'd check it out
Old Jun 13, 2006 | 09:41 AM
Hawkze_2.3's Avatar
I bet $$$$ that the connector for the VSS (vehicle speed sensor) is f'ed up in some way.
There are many many threads on this topic and a little searching will give you lots of answers.
Old Jun 13, 2006 | 10:35 AM
Chuckles99SH's Avatar
Default Re: my first post and question (Hawkze_2.3)
Same, VSS is probably your problem.. is your Tach working as intended?
Old Jun 13, 2006 | 01:02 PM
f155mph's Avatar
Default Re: my first post and question (Chuckles99SH)
Not aftermarket.
Yes the tech works fine. Can someone tell me where the VSS is located at?
Lastly how would the altenator affect the speedometer?
Old Jun 13, 2006 | 04:49 PM
AnthonyG2003
Guest
Posts: n/a
I would put my money on the alternator...It did the same thing to my friends 00 Civic Si...Tach would work but the speedo wouldnt. At least check that!
KrenzyRyan
33
Aug 1, 2007 03:08 PM
pat671
Nov 12, 2006 08:01 PM
4dr-Si
Sep 14, 2006 05:05 PM
importdreamer
21
Jan 6, 2005 06:10 PM
jsteezy1290
16
Feb 9, 2004 06:17 PM
