My prelude is revving from 1200 to 3000, constantly, HELP!
Old 06-11-2006, 09:28 PM
sitcomactor3's Avatar
Default My prelude is revving from 1200 to 3000, constantly, HELP!
My '95 Honda Prelude's idle is revving from about 1200-3000, CONSTANTLY, when I'm in neutral (manual trans). It goes up & down like clockwork, man. It goes up to 3000 then goes back down to 1200 then it goes right back up to 3000 & then back down to 1200.
I ran out of gas recently & that's when the problem immediately began. I put in a new fuel filter, to no avail. Is the problem in my fuel pump (which is located in the tank, or just outside of the tank behind my rear seat, I think), or is it something else? The revving is driving me absolutely bonkers, so if you could help, I'd really appreciate it. I don't want to spend the money on a new fuel pump, only to find out it's something else.
I heard another Honda (Civic) revving just like mine & I wanted to pull the guy over & ask him if he'd run out of gas recently, too. I've had the car for 6 years, with no problems. It still gets 25 mpg, thereabouts, and once I'm driving above 2500 rpm, it revs & drives normally...
Please help.
Thanks -- Bobby
Old 06-11-2006, 09:59 PM
preludeguy_92's Avatar
Default Re: My prelude is revving from 1200 to 3000, constantly, HELP! (sitcomactor3)
Sounds like a vacume leak.
Old 06-11-2006, 10:20 PM
Ludster's Avatar
Default Re: My prelude is revving from 1200 to 3000, constantly, HELP! (preludeguy_92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeguy_92 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a vacume leak.</TD></TR></TABLE>
+1
Also check if ur Fast Idle Valve is broken. That makes idle jump as well.
Old 06-11-2006, 10:27 PM
HondaPH22's Avatar
mine did that when i put a throttle body spacer on. u didnt install one of those did you?
Old 06-12-2006, 12:51 AM
siklude-bb6's Avatar
sounds like a vac. leak...or LIKE THEY SAID fast idle control valve...i had the same prob .twice....first was fast idle. second vac. leak i had a busted Intake Man. GASKET!!!!..its an easy fix
Old 06-12-2006, 05:52 AM
92hondalude's Avatar
Default Re: My prelude is revving from 1200 to 3000, constantly, HELP! (bb6jdm1)
FICV
Old 06-12-2006, 08:33 AM
Dai_Ca_Vietnam_H22a4's Avatar
Fast Idle Valve Controller is broken. Open the controller and screw in the plastic gasket-like srew inward. Over time the screw unscrews itself. This causes the vacuum leak.
Old 06-12-2006, 09:28 AM
Default Re: My prelude is revving from 1200 to 3000, constantly, HELP! (Dai_Ca_Vietnam_H22a4)
Thanks, Guys, I really appreciate the help. I thought it might have something to do with a gasket or some other unknown airflow problem. Now, I guess I better go get a Chilton's (or look it up on the internet), to find exactly what & where the aforementioned Fast Idle Valve Controller is located, as I have NO clue, lol!
Point me in the right direction, thanks!
I won't know what to do if I don't hear that constant revving...everyone knows when I'm coming (as I have an exhaust leak, too!), particularly my family, my dogs, and my neighbors...
I'm off to try to find the Fast Idle Valve Controller, wish me luck!
-- B
Old 06-12-2006, 09:25 PM
Honda Sport's Avatar
does it have an irratic idle when cold or when it's warm? fingers point to FITV when cold or IACV when warm. like what others said, could be a vacuum leak also.
Old 06-13-2006, 04:51 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (Honda Sport)
try going to 92lude.com and trying their fix for this problem...Search on here for the link...I had the same problem then did their fix and it worked for me.
Old 06-13-2006, 07:33 AM
CD5 Jeebies!'s Avatar
Location: Free bullets if you find me sucka, Washington
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dai_Ca_Vietnam_H22a4 &raquo;</TD></TR><TR><TD CLASS="quote">Fast Idle Valve Controller is broken. Open the controller and screw in the plastic gasket-like srew inward. Over time the screw unscrews itself. This causes the vacuum leak. </TD></TR></TABLE>
This is your problem..has nothign to do with you being cheap and running out of gas!
Old 06-13-2006, 02:00 PM
* B A N N E D *
bigdaddyvtec's Avatar
x2 for teh win
Old 06-19-2006, 03:36 AM
Default Re: My prelude is revving from 1200 to 3000, constantly, HELP! (I got the CD5 Jeebies!)
Did that fix the Problem???
mhewitt
12-22-2010 07:27 AM
confucioussae
09-04-2006 10:12 PM
recap
15
08-26-2006 09:27 PM
silverb18
04-24-2005 06:31 PM
Quick Reply: My prelude is revving from 1200 to 3000, constantly, HELP!
