Compression Test Results
Old Jun 11, 2006 | 07:30 PM
John.'s Avatar
Default Compression Test Results
Okay, so i finally got to do a compression test on my car today. And i got pretty bad numbers. I'm thinking of re-testing tmrw morning...
Engine is a USDM H22A1. 100,015 miles.
C1=90
C2=118
C3=122
C4=138
So should i just bury it or is there hope for it yet?
edit: forgot to mention the engine is not running.
Modified by d4rkn1t3 at 9:20 PM 6/11/2006
Old Jun 11, 2006 | 07:43 PM
bb_one's Avatar
Default Re: Compression Test Results (d4rkn1t3)
Try doing a compression test with the throttle wide open. See if your numbers change. But most of the time a compression test checks for your consistancy between cylinders. If your #1 cylinder still shows the lowest number, try doing a leaking down test for a more precise diagnosis.
Old Jun 11, 2006 | 10:41 PM
John.'s Avatar
Default Re: Compression Test Results (bb_one)
im gonna try a WOT compression test also gonna see what kind of numbers i get with a little oil. If the numbers improve alot with the oil i may have found my problem... if not i may have some ef'd up valves.
Old Jun 11, 2006 | 10:43 PM
98vtec's Avatar
moderator emeritus
goodluck.
Old Jun 11, 2006 | 10:57 PM
John.'s Avatar
Default Re: Compression Test Results (98vtec)
dude if i ever get this god damn thing running, im gonna get some itb's on there...someday. Been reading your thread and i'm loving your setup.
Old Jun 12, 2006 | 07:57 AM
TheAccordGuy's Avatar
Does not make a difference if you leave the throttle open or not, Ive tested both ways and saw no difference. With these numbers you are getting its time for a rebuilt no need to do a leak down, the motor has been beat and the nothing you can do other than rebuilding it.
Old Jun 12, 2006 | 08:45 AM
PrecisionH23a's Avatar
Default Re: (TheAccordGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">Does not make a difference if you leave the throttle open or not, Ive tested both ways and saw no difference. With these numbers you are getting its time for a rebuilt no need to do a leak down, the motor has been beat and the nothing you can do other than rebuilding it.</TD></TR></TABLE>
It does matter if your throttle is open. If you don't open your throttle you won't get anough air to your cylinders to create pressure.
76 camaro car
Apr 20, 2017 04:47 AM
humboldt_skim
May 31, 2008 08:18 AM
Azcheron
Jun 23, 2005 09:34 PM
Slick GS-R
Apr 23, 2002 02:15 PM
