ARP Head Stud Question
Old Jun 14, 2006 | 10:28 AM
ItsSlowYo's Avatar
Default ARP Head Stud Question
Has anyone else installed ARP head studs on a H22A1 (close deck) engine?
I was curious if anyone else has run into any problems with the stud lengths.
I ordered a set and the part number is for the H22A4, and there is no part number the the H22A1. I called up ARP with the part number and ARP says there is no difference between the two.
http://www.prostreetonline.com/buy/arp_head_studs/
Any help would be greatly appriciated.
Thanks,
Old Jun 14, 2006 | 11:55 AM
Eddiebx's Avatar
they are the same thing,
Old Jun 14, 2006 | 11:58 AM
ItsSlowYo's Avatar
Default Re: (Eddiebx)
I can tell you they are NOT the same, I have tried them. The head studs are not the correct length.
The only thing I can guess is maybe the difference is because of the open vs. closed deck.
Old Jun 14, 2006 | 12:21 PM
v4lu3s's Avatar
RTFM
then i guess a lot of people are doing things wrong cause they work great on my closed deck h22a.
Old Jun 14, 2006 | 12:27 PM
98vtec's Avatar
moderator emeritus
Default Re: (ItsSlowYo)
being open or closed deck does not change the deck height or dimensions of the motor.
Old Jun 14, 2006 | 01:28 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">they are the same thing, </TD></TR></TABLE>
Yep.
Old Jun 14, 2006 | 02:43 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItsSlowYo &raquo;</TD></TR><TR><TD CLASS="quote">I can tell you they are NOT the same, I have tried them. The head studs are not the correct length.
The only thing I can guess is maybe the difference is because of the open vs. closed deck. </TD></TR></TABLE>
i guess those idiots at ARP just don't know what they are doing they should be shot
Old Jun 14, 2006 | 11:52 PM
Rosko's Avatar
I had the same question a long time ago.
I'm pretty sure the part #'s are different from Honda on the stock bolts too, but if they work then they work.
Old Jun 15, 2006 | 07:50 AM
Eddiebx's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">I had the same question a long time ago.
I'm pretty sure the part #'s are different from Honda on the stock bolts too, but if they work then they work.</TD></TR></TABLE>
yes the stock ones are 6pt bolts on the 92-96 and 12pt bolts on the 97+ i believe. i am not sure what yr they made the change, but thats the difference, in the bolt head.
Old Jun 15, 2006 | 09:39 AM
Rosko's Avatar
yes the stock ones are 6pt bolts on the 92-96 and 12pt bolts on the 97+ i believe. i am not sure what yr they made the change, but thats the difference, in the bolt head.</TD></TR></TABLE>
good to know.
Old Jun 16, 2006 | 06:49 PM
92hondalude's Avatar
Default Re: (Rosko)
damn i payed 20 more for the h22a4 then the h22a
Old Jun 17, 2006 | 06:22 AM
Eddiebx's Avatar
Default Re: (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">damn i payed 20 more for the h22a4 then the h22a </TD></TR></TABLE>
shouldve just got the arps to begin with,
pcguy760
Jun 1, 2011 06:55 AM
ludekid4323
Oct 16, 2008 05:42 AM
kornerk12
May 6, 2007 09:25 AM
9seccivicsi
Sep 20, 2004 10:55 AM
sargentboy
Nov 16, 2003 07:14 AM
