Prelude LSD????
Old Jun 15, 2006 | 09:14 PM
prelude1911's Avatar
Default Prelude LSD????
I have 1997 Turbo Honda Prelude SH that making over 300whp. 1st and 2nd gear goes no wear but wheel spin. I looking to take out the atts which is in inactive and replace the tranny with a LSD tranny. I was just wanted some opinions. The JDM Prelude SIR with the m2b4 tranny goes for like 1g and has the oem lsd. The quaife or Kaaz LSD around 750-1,000 plus installation. Is there a big difference with going with one of the aftermarket company then the honda oem lsd? Besides the price. What you guys think?
Old Jun 15, 2006 | 09:22 PM
vinuneuro's Avatar
Default Re: Prelude LSD???? (prelude1911)
You can't fit an lsd in the m2u4 transmission. You can't easily use any other transmission without fab work.
Old Jun 16, 2006 | 08:50 AM
Default Re: Prelude LSD???? (vinuneuro)
I am not going use the SH tranny. I either will go with the M2B4 tranny if i want the honda oem lsd. or if I go with a aftermarket lsd i will probably get a 1992-96 prelude tranny. Either way I will need new axles and a intermediate shaft. I just want to know if you think the m2b4 tranny is as goog as a tranny equipped with a quaife lsd?
Old Jun 16, 2006 | 09:19 AM
Chuckles99SH's Avatar
Dude its gonna be a bitch to mount any tranny to a SH block.. you need a custom fab adapter plate.. the local tuner shop in the area wont do these because they say they are unstable/unrelyable. There are a few members that have done it but from what ive read and heard is that its kinda a ghetto patch job to rig it.
Old Jun 16, 2006 | 10:33 AM
Default Re: Prelude LSD???? (Chuckles99SH)
yea i know that you have the fabricate a plate so the intermediate shaft bolt on where the atts used to be. im not worried about that. i work at a machine shop. by the way if i get this plate working u think i can produce a couple of them to sell? wat about the different lsd?
Old Jun 16, 2006 | 10:38 AM
bad-monkey's Avatar
the M2B4 helical LSD unit isn't a bad LSD. it's basically a quaife, but without the lifetime guarantee and probably doesn't engage as smoothly. It's an easy way to get the LSD in your car, without having to take everything apart and install, on top of having to create the adapter plate.
however, the ultimate prelude tranny is probably an M2F4 (4th gen vtec) b/c it has the closest gear ratios w/ a quaife or kaaz. The quaife will be less maintenance, as the kaaz will need occasional rebuilds to replace the worn clutchpacks, since the quaife is a gear-type and the kaaz is a clutch type. the kaaz however, has a much more agressive engagement.
i'd go with the m2b4, but the m2f4+quaife is also a solid choice.
Old Jun 16, 2006 | 10:44 AM
vinuneuro's Avatar
Default Re: (bad-monkey)
The m2b4 (or any non-m2u4) isn't going to mount to his SH block without the adapter plate though..
Old Jun 16, 2006 | 11:24 AM
thanks for the feedback. i probably go with the m2b4. can't wait to have it on. 300whp is nothing if ur not getting any grip.
Old Jun 16, 2006 | 01:47 PM
98vtec's Avatar
moderator emeritus
Default Re: (prelude1911)
thats why all motor rocks
m0sad
Transmission & Drivetrain
Aug 6, 2015 08:29 AM
vteclude07
Jul 15, 2007 07:44 PM
donnybrasco
Apr 30, 2006 10:40 AM
Lude454
Apr 2, 2005 04:32 PM
Hanza
Aug 26, 2004 02:29 AM
