cooling system question
Old Jun 19, 2006 | 02:23 PM
tonezilla's Avatar
Default cooling system question
it's an h23 in a 94 accord . i am trying to figure out what the problem is with my car . i was driving it the other day and i saw a little smoke coming out from the engine bay . the water temp gauge did not go all the way up when it happened, but i pulled over at my friends place, and i saw smoke, steam, and coolant spraying out from a tiny spot, like a size of a pin needle, on the radiator, i was wondering if i could fix this with some jb weld or do i need to buy a new radiator ?
i also tried to test to see if my thermostat was bad . i started up my car to warm it up . it warmed up in 5 mins, but i gave it another 10 mins because the radiator fan did not come on . the fan is supposed to come on after it warms up though right ? but then someone told me maybe it just takes a longer time for my car to warm up . also, when i turned on the a.c/heater, dont know which one turned it on, but the fan started working immediately, so i went to see if my lower radiator hose was hot, but it was still cold ? so what the hell is going on with my car ? can anyone provide some info .
Old Jun 19, 2006 | 11:51 PM
mgags7's Avatar
if the lower hose is cold, the thermostat either hasnt opened yet or is stuck shut
if you have a leak from the radiator you should replace it, i wouldnt trust jb weld crap for more than a temp fix so you can get home....
Old Jun 20, 2006 | 12:01 AM
Rosko's Avatar
Default Re: (mgags7)
No JB weld but a good radiator shop can prolly fix it right.
Old Jun 20, 2006 | 09:40 AM
tonezilla's Avatar
Default Re: (Rosko)
how long does it usually take for a thermostat to open ? is warming up the car not hot enough, so i need to drive the car around for a little bit and then test it ?
also, how much do radiator shops usually charge to fix a leak ?
Old Jun 20, 2006 | 10:00 AM
Hawkze_2.3's Avatar
Default Re: (tonezilla)
Is sounds like you just need to fix the little hole in the radiator and get a new thermostat. No big deal...
Old Jun 20, 2006 | 11:15 AM
tonezilla's Avatar
Default Re: (Hawkze_2.3)
yeah, that's what i was thinking . but i was just wondering if i can seal up the leak myself ? and if so, what should i use to seal it up ?
Old Jun 20, 2006 | 11:43 AM
Rosko's Avatar
I put a couple holes through the readiator on my quad and had it fixed for $50 bucks. They used solder and then pressure tested it too.
Old Jun 20, 2006 | 01:23 PM
AndyD's Avatar
Default Re: cooling system question (tonezilla)
I don't know about you guys but the cooling system of a car is NOT something I mess with. I had the same problem you did. I replaced the radiator (~$115 shipped to me), the radiator hoses, and theromstat all at the same time. The last thing I want is to have a problem while driving late at night by myself, or with somone else only to get stranded.
Tires, brakes, and cooling system are the main things I make sure are in good condition. Skimping on them likely leads to higher costs and a lot of inconvenience.
Old Jun 21, 2006 | 09:58 AM
tonezilla's Avatar
Default Re: cooling system question (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I replaced the radiator (~$115 shipped to me), the radiator hoses, and theromstat all at the same time.</TD></TR></TABLE>
was that for a new radiator ?! if so, can you tell me where ? i was thinking about buying a cheap one off of ebay, but i dont know if it is worth it .
http://cgi.ebay.com/ebaymotors...=true
Modified by tonezilla at 11:17 AM 6/21/2006
Old Jun 21, 2006 | 10:57 AM
Hawkze_2.3's Avatar
Also check out http://www.radiators.com and http://www.radiatorbarn.com.
Old Jun 21, 2006 | 11:58 AM
tonezilla's Avatar
Default Re: cooling system question (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Also check out http://www.radiators.com and http://www.radiatorbarn.com.</TD></TR></TABLE>
have you bought from these dealers before ? they have good prices but i dont know how the quality of the radiator is .
Old Jun 21, 2006 | 12:53 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonezilla &raquo;</TD></TR><TR><TD CLASS="quote">
http://cgi.ebay.com/ebaymotors...=true </TD></TR></TABLE>
I can't remember where i bought it from. I bought it online. It's new with a lifetime warranty.
The link you posted to the Ebay auction will NOT fit your Prelude if you have an H23 or H22 engine. That will ONLY work on a Prelude S. Trust me on this.
Old Jun 21, 2006 | 01:49 PM
Jagan'92's Avatar
I think you got it from radiatorexpress.com, that was 115$, but you traded it for one with a lifetime warranty? it was only a couple years ago, sheesh, whaddya
fuglybutruns
Jul 28, 2015 07:50 PM
x justin
Feb 17, 2015 05:02 PM
supermotothud
Dec 19, 2008 01:38 AM
spock_rocker
Jun 6, 2005 03:32 PM
dockersguy
Jul 23, 2004 09:01 AM
