Installing coilovers
Old Jun 15, 2006 | 02:50 PM
Takymoto's Avatar
I'm a Jackass
Default Installing coilovers
Are there any writeups for installing full coilovers on 4th gen preludes? Any help will be GREATLY APPRECIATED.. thanks
Old Jun 15, 2006 | 03:06 PM
bb4socal's Avatar
you dont need one... its pretty basic. Take the rim off..and just spend a couple minutes and look at what you would have to unbolt. You may need a spring compressor just to get the stock springs out.
Old Jun 15, 2006 | 04:38 PM
PiNoY_BB6's Avatar
Default Re: Installing coilovers (PEARLelectron)
you do need a spring compressor... you can get one at any of your local auto shiops, and it aint expensive at all...
Old Jun 15, 2006 | 08:55 PM
bunkass's Avatar
I used this website for the fronts http://www.ntpog.org/mods/fift...shtml
and this website for the rears
http://www.geocities.com/joon525/Teins/Tein.htm
Old Jun 15, 2006 | 10:12 PM
tytyguy's Avatar
Default Re: Installing coilovers (bunkass)
i got my spring compressor from autozone you can rent it for free. id do that because you probably wont need them anymore.
Old Jun 15, 2006 | 10:20 PM
Hawkze_2.3's Avatar
Well, if you're installing full coilovers then you just take out the stock suspension as one piece and put the coilover setup in. But if it's something like a coilover sleeve that you have to install over a seperate shock, then you will need a spring compressor......just depends.
Old Jun 16, 2006 | 05:38 AM
esedulerp5tenin's Avatar
Default Re: Installing coilovers (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Well, if you're installing full coilovers then you just take out the stock suspension as one piece and put the coilover setup in. But if it's something like a coilover sleeve that you have to install over a seperate shock, then you will need a spring compressor......just depends.</TD></TR></TABLE>
stole the words right outta my mouf
Old Jun 18, 2006 | 09:26 AM
djbrandonr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Well, if you're installing fullif it's something like a coilover sleeve that you have to install over a seperate shock, then you will need a spring compressor......just depends.</TD></TR></TABLE>
I dont even bother w/ a compressor. I just stand on the shock and spring and then undo the top hat nut. You get a good rush right before it pops, but nutin really comes flying off.
Old Jun 18, 2006 | 12:39 PM
soundbomber's Avatar
Default Re: Installing coilovers (djbrandonr)
beware the wrath of darwin
Kyles ej1
15
Sep 25, 2004 07:33 PM
streetspeed607
Apr 17, 2004 11:31 PM
Accord98
Jul 25, 2003 11:20 PM
FastAndFatalLude
Mar 23, 2003 09:50 PM
TEK_02
Jul 30, 2002 08:43 AM
