engine not turning over
Old Jun 17, 2006 | 11:13 PM
homesauce's Avatar
Default engine not turning over
It used to click, now it doesn't make any noise. The search is down, and I'd like some recommendations,
Here's what I've tried.
Checked the battery and recharged it, replaced starter, checked fuses.
Any other ideas would be greatly appreciated.
Old Jun 17, 2006 | 11:48 PM
Leo C's Avatar
Night Owl
Default Re: engine not turning over (homesauce)
have you tried to roll-start it?
Old Jun 18, 2006 | 12:00 AM
ErMaK's Avatar
Default Re: engine not turning over (shutupnskate)
Ignition Coil maybe?
Old Jun 18, 2006 | 12:13 AM
Leo C's Avatar
Night Owl
Default Re: engine not turning over (ErMaK)
a faulty ignitor or coil could also cause this.
Old Jun 18, 2006 | 07:48 AM
PrettyLude's Avatar
checked the connections on the battery and the starter? maybe the spade terminal on the starter itself fell off?
Old Jun 18, 2006 | 08:38 AM
SKDRCR's Avatar
Default Re: (PrettyLude)
so the car is cranking but not turning over then?
Old Jun 18, 2006 | 08:54 AM
GlenWatkins's Avatar
Default Re: (SKDRCR)
There is a small black wire that runs across the transmission and connects to the starter solenoid. This wire carries the signal from the ignition switch for turning on the starter motor. Check to make sure the wire doesn't have a bare spot and is shorting out on the transmission case. My 3rd gen did exactly that.
Pagley
Sep 4, 2010 12:05 PM
bayoufrogg
Oct 24, 2006 08:18 PM
jbs
Oct 3, 2006 10:26 AM
candyman206
Feb 9, 2006 10:09 PM
Nisif
Nov 3, 2005 08:34 PM
