TDC question
Old Jun 11, 2006 | 03:40 PM
PreludePhill's Avatar
Default TDC question
im doing my timing belt install and i have the engine out of the car. and the flywheel is off,do all of these have to point to 12 o clock to be TDC?
Old Jun 11, 2006 | 06:44 PM
Hawkze_2.3's Avatar
Default Re: TDC question (N2oH22)
Well, the pics on the right and bottom are the balance shaft pulleys. Different belt and setup than the timing belt.
Do you not have a flywheel you could stick on there to set the timing? It really helps...
Old Jun 12, 2006 | 04:20 AM
Mikey3000's Avatar
you dont need your flywheel. there is a dot on the timing belt pulley (inner-most pulley) on the crank shaft that should point to an arrow on the oil pump housing. that'll give you #1 tdc.
Built B16A
Aug 6, 2008 03:14 AM
needVtec
Jul 4, 2005 12:19 PM
gsf4726
Nov 17, 2003 05:40 PM
WONG FRIED RICE
Nov 11, 2001 12:30 PM
