Shift/Transmission Problem
Old Jun 19, 2006 | 06:56 AM
Trian's Avatar
Default Shift/Transmission Problem
Recently my transmission has been acting up. To make this short and to the point... I've had the shift **** get stuck in neutral and unable to shift into gears on more than a couple of occassions (most of the time in the early morning) and also when I shift into 5th gear at higher speeds, it acts like the shifter doesn't fall perfectly into the gear and it grins just a little (like actually from the shifter not the tranny). At lower speeds (around 45mph), if I shift into 5th it goes smooth but as I said like above 55mph+ it gets worse.
Any advice on what this could be? I've taken it to a shop and they told me it's an interternal transmission problem and that it's going to have to be rebuilt in short (they said the syncros were out, bearings, etc etc trying to jack me I'm sure).
** edit **
Oh, and btw it's on my 93 H22A VTEC.
Old Jun 19, 2006 | 07:48 AM
darkspector's Avatar
Sounds like syncro's to me too.... But make sure you good on tranny fluid
Old Jun 19, 2006 | 02:33 PM
tcontesh's Avatar
Default Re: Shift/Transmission Problem (Trian)
search this one cause there should be alot of results, alot of 5th gens have this issue
'95 BA8
Jun 18, 2010 06:46 AM
BB1LOViN
Jul 11, 2008 02:28 AM
naptownrex
Aug 20, 2006 10:29 AM
omg_miiiike
10
Apr 17, 2005 12:35 PM
