what to pull/disconnect for compression test
Old Jun 21, 2006 | 02:38 PM
budget's Avatar
Default what to pull/disconnect for compression test
5th gen
do i just pull the clock/radio fuse under the hood?
Old Jun 21, 2006 | 02:47 PM
98vtec's Avatar
moderator emeritus
Default Re: what to pull/disconnect for compression test (your)
pull out your spark plugs so you can turn the crank easier. Thats about it.
Old Jun 21, 2006 | 02:55 PM
budget's Avatar
Default Re: what to pull/disconnect for compression test (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">pull out your spark plugs so you can turn the crank easier. Thats about it.</TD></TR></TABLE>
i know that.. im just wondering what fuse to pull before i do it
Old Jun 21, 2006 | 02:57 PM
98vtec's Avatar
moderator emeritus
u dont need to pull out any fuse.
Old Jun 21, 2006 | 02:58 PM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">u dont need to pull out any fuse.</TD></TR></TABLE>
wont it clog the injectors?
98vtec's Avatar
moderator emeritus
my bad, pull out the fuel pump fuse
VtecFreePrelude's Avatar
just disconnect your coil
Old Jun 21, 2006 | 02:59 PM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">my bad, pull out the fuel pump fuse </TD></TR></TABLE>
is that in the fues box thats under the hood? doesnt the clock/radio fuse control the ecu which controls the injectors?
Old Jun 21, 2006 | 03:00 PM
98vtec's Avatar
moderator emeritus
Old Jun 21, 2006 | 03:02 PM
budget's Avatar
i lost that cover, is it all 3 of the fuses?
Old Jun 21, 2006 | 03:03 PM
98vtec's Avatar
moderator emeritus
no, the red circle is just the fuse puller. The two fuel pump fuses are the two 7.5 fuses circled in blue
Old Jun 21, 2006 | 03:04 PM
98vtec's Avatar
moderator emeritus
i'm only seeing 2 and the fuse puller
Old Jun 21, 2006 | 03:08 PM
budget's Avatar
what would pulling the clock/radio fuse do?
Old Jun 21, 2006 | 03:13 PM
98vtec's Avatar
moderator emeritus
your clock and radio wouldnt work and it would reset the ecu.
Old Jun 21, 2006 | 03:15 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
I didn't take any fuses out on my car. Compression was great and it still runs great if that makes you feel any better.
Old Jun 21, 2006 | 08:49 PM
vinuneuro's Avatar
x2 for pulling the fuel pump fuses.
Old Jun 22, 2006 | 09:52 AM
577HondaPrelude's Avatar
Default Re: what to pull/disconnect for compression test (vinuneuro)
I disconnect all 4 fuel injectors and leave all fuses in the car. The wire connectors to the injectors just pop right off. This way I know no fuel will enter the chamber. With the fuel pump off there is still going to be some fuel pressure that will let the injectors work for a while until all the pressure is bled out.
Spark plugs need to be out also, but that's obvious because that's were the compression test tool goes.
either way will work, and a little fuel in there will not really hurt anything, but I'm **** like that.
Old Jun 22, 2006 | 11:08 AM
Mr.Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">pull out your spark plugs so you can turn the crank easier. Thats about it.</TD></TR></TABLE>why would u need to turn the crank??
Old Jun 22, 2006 | 11:10 AM
Mr.Luder's Avatar
here
linky---&gt; http://www.c-speedracing.com/h...t.php
only diff. is for a h22 u disconnect the coil
Old Jun 22, 2006 | 11:14 AM
Hawkze_2.3's Avatar
Default Re: what to pull/disconnect for compression test (Mr.Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">why would u need to turn the crank??</TD></TR></TABLE>
You're going to be cranking the engine over many times and it'll make it a lot easier on your battery and starter if the engine isn't making compression.
Old Jun 22, 2006 | 11:23 AM
Mr.Luder's Avatar
Default Re: what to pull/disconnect for compression test (Hawkze_2.3)
but isn't that the whole point of a compression test?
Old Jun 22, 2006 | 11:49 AM
Hawkze_2.3's Avatar
Yeah, the compression tester goes in the spark plug hole for the cylinder you are testing and seals the cylinder just like the spark plug.
Old Jun 22, 2006 | 12:34 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">but isn't that the whole point of a compression test?</TD></TR></TABLE>
you can only test one cylinder at a time.
crazyemokid
35
Jun 8, 2006 12:08 PM
BlueShadow
25
Jul 8, 2005 09:43 AM
Scean
Aug 23, 2004 06:50 PM
RGoose18
May 23, 2004 11:44 PM
JDM_ITR
Jul 6, 2003 09:53 AM
