5th gear issue
Old May 3, 2004 | 12:33 PM
PreludeMTX's Avatar
Default 5th gear issue
Have a 92 S and when shifting into 5th after about a minute or so it pops out of gear. I pressed my hand against the stick and I can feel it wanting to push out. Every other gear is fine. Does any know what the hell is causing this?? Any help greatly appreciated..
Old May 3, 2004 | 02:20 PM
dr.bushpusher's Avatar
Default Re: 5th gear issue (PreludeMTX)
first i would check the linkages and make sure there
is nothing in the way rubbing against the linkage
Old May 3, 2004 | 02:26 PM
4bidden's Avatar
Are you using a short shifter?
Old May 4, 2004 | 09:27 AM
PreludeMTX's Avatar
No short shifter..I have never expirenced this and hopin the tranny is ok. There is no grinding or anything either, just pops out of gear. I just replaced the clutch 3000 miles ago, but I dot think that has anything to do with it. I dont want to be takin by the mechanic saying I need a new tranny when I dont or something like that..
Old May 4, 2004 | 09:52 AM
did you check the linkages yet?
Old May 4, 2004 | 10:13 AM
PreludeMTX's Avatar
Default Re: 5th gear issue (dr.bushpusher)
I did, didnt see anything out of the ordinary..what else do you think it could be?
Old May 4, 2004 | 12:24 PM
Then it's probably your 5th gear synchronizer.
does it grind giong into 5th as well?
Old May 4, 2004 | 02:29 PM
PreludeMTX's Avatar
no grinding at all..goes in smooth. about a minute later it pops out. I can keep it in gear by firmly holding the shifter. But once i ease the pressure i can literally feel it pushing out wanting to get to neutral. It only pushes back when i accelerate..im stumped and dont want to pay out my A$$ for somethin i dont know and could be an easy fix..
Old May 4, 2004 | 07:52 PM
jdmh22atch's Avatar
i am running a jdm h22a and have been through both jdm and usdm tranmissions and all i have to say is that h22 a transmissions suck. but the one thing that i have found after running royal purple and trying all types of things , i am now running moble 1 5w 30 and it reduces grind and poping out of gear greatly. try that if u haven't all ready.
Old May 7, 2004 | 06:51 AM
BMG's Avatar
BMG
My friend has an RSX type S that does the same thing in 6th. The dealer said it has something to do with the transmission but that Acura hasn't come out with a fix for it though.
Old May 7, 2004 | 12:55 PM
PreludeMTX's Avatar
Default Re: 5th gear issue (BMG)
transmision problem huh..thats the one thig i didnt wanna hear..i have heard of road vibrations and what not causing this but there is certainly something else at work here..its goin to the shop monday, if its a tranny prob looks like i will be driving in 4th alot....
Old May 7, 2004 | 12:59 PM
yellow_jacket's Avatar
Usually if it pops out of gear that is a syncro problem. They don't always grind when you experience this either.
Old May 7, 2004 | 03:54 PM
PreludeMTX's Avatar
Default Re: 5th gear issue (yellow_jacket)
thats what im hopin..thanx for the insight
92eg6lsvtec
Jul 9, 2008 07:08 PM
si_ek
May 22, 2008 07:43 AM
eric416
Jun 23, 2006 02:10 PM
WhiteVX
May 19, 2006 04:37 PM
