how much boost
Old Apr 29, 2004 | 12:00 AM
[LUDE]'s Avatar
Default how much boost
I put a turbo on my 92 prelude (h22a) was just wondering wats that max boost i can run . ive decompressed the engine using pistons out of my old motor (h23) im curently running 12 psi to b safe how much more can i go .and wat compresion do u think im running ?
Old Apr 29, 2004 | 12:54 AM
musclefella's Avatar
Default Re: how much boost ([LUDE])
H23 compression is 9.8:1, so i geuss your compression should be around that number. That is still pretty high. 12 psi is a bit on the high side and should only be run ones in a while. Because you still have a relative high compression, you'll need less boost to get alot of horse power. I hope you know what your doing, cause with high compression and that kind of boost, the marging for error is very very small.
I'd suggest that you run 8 psi and 10 to 12 psi at the races ones in a while.
Good luck and dyno the car and have it tuned properly.
Old Apr 29, 2004 | 03:06 AM
[LUDE]'s Avatar
theres like a 1 or 2 mm gap from the top of the piston n the block were it was flush on the h23 block
Old Apr 29, 2004 | 04:18 AM
PrecisionH23a's Avatar
I'd run about 10 cans of boost... if you really want to you can throw in 3 or 4 bars too.
seriously, try a search. sorry to be an ***, but you'll find ALL the info you'll ever need on this topic as it is discussed 10x a week.
Old Apr 29, 2004 | 05:07 AM
fastludeh22's Avatar
Default Re: how much boost (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by musclefella &raquo;</TD></TR><TR><TD CLASS="quote">H23 compression is 9.8:1, so i geuss your compression should be around that number...</TD></TR></TABLE>
h22 head has a bigger cc, so the compression ratio should be lower then that, not sure how much thoough.
what kind of fuel mgmt you using?
Old Apr 29, 2004 | 11:41 PM
[LUDE]'s Avatar
Default Re: how much boost (fastludeh22)
wolf 3d ems .....Im from austailia so dunno if use have it were ur from
boostedhks
Feb 8, 2009 01:10 PM
rsx13k
May 25, 2007 12:38 PM
rb08
Aug 26, 2003 07:52 AM
Spoold_R
Jan 11, 2003 02:36 PM
AzN_Flava
May 12, 2002 05:35 PM
