initial timing
Old May 2, 2004 | 09:11 AM
hOndafienD 04's Avatar
Default initial timing
what do i have to plug/unlug for me to set initial timing on my 92 si? @ what rpms should it be at during idle? thanx....need this asap!!!!
Old May 2, 2004 | 04:33 PM
any1? come on someone gotta know this.
Old May 2, 2004 | 04:58 PM
stareatsun's Avatar
Default Re: initial timing (hOndafienD 04)
are you talking timing as in a new timing belt to line up properly? Idle should be at 700-800 rpm also
Old May 2, 2004 | 06:18 PM
nope...ignition timing...sorri for not being clear on that
Old May 2, 2004 | 07:29 PM
mattmw88's Avatar
Default Re: (hOndafienD 04)
you should have a hole on between your tranny adn block so you can see the flywheel rotate. LOSEN (don't take them out!) the three bolts on your distributor adn turn the entire distributor from left to right until the line on your flywheel is in between the little fork. In other words take the timming light and aim it at the hole. Look carefully and you will see a line on the flywhel as it goes around on the left side. On the right there will be a fork like looking peice of metal that you should line the mrk on the flywheel up with. Good luck and get a helms, you'll love it. Also your idle should be at 700 +-50 rpm.
Old May 3, 2004 | 07:30 AM
prelittlelude's Avatar
Default Re: (mattmw88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattmw88 &raquo;</TD></TR><TR><TD CLASS="quote">you should have a hole on between your tranny adn block so you can see the flywheel rotate. LOSEN (don't take them out!) the three bolts on your distributor adn turn the entire distributor from left to right until the line on your flywheel is in between the little fork. In other words take the timming light and aim it at the hole. Look carefully and you will see a line on the flywhel as it goes around on the left side. On the right there will be a fork like looking peice of metal that you should line the mrk on the flywheel up with. Good luck and get a helms, you'll love it. Also your idle should be at 700 +-50 rpm. </TD></TR></TABLE>
also if you don't jump the service connector when you do this the ecu will just correct for your "miss ajustment" . and then you will have wasted your time.
Old May 3, 2004 | 12:35 PM
yeah..thanx!
anomale
Nov 30, 2008 01:34 PM
Peter Brady onlyonweekndz
Dec 25, 2007 11:18 AM
bassysingh
Oct 17, 2005 10:02 AM
jaydemlude
Mar 9, 2005 03:46 PM
KooK
11
Jun 4, 2003 09:26 AM
