Fuel Cutoff Problems
Old May 2, 2004 | 10:15 PM
99BlackSH's Avatar
Default Fuel Cutoff Problems
I own a 1999 Honda Prelude SH,
my fuel cutoff engages at 6800, but it should be engaging in the late 7k or early 8k rpms.
any ideas?.
BTW I have been told I could be in LIMP/SAFE mode, but I can still hit VTEC so that is odd.
Old May 3, 2004 | 05:53 AM
rjr162's Avatar
Default Re: Fuel Cutoff Problems (99BlackSH)
Are you absolutely sure you're hitting VTEC and its' just not the 2ndaries opening? As far as I know if you hit the ~6400 RPM limiter, then the VTEC won't engage either. I'd check the typical things like oil level, is the car up to temp, is the VTEC unit's wire plugged it, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99BlackSH &raquo;</TD></TR><TR><TD CLASS="quote">I own a 1999 Honda Prelude SH,
any ideas?.
BTW I have been told I could be in LIMP/SAFE mode, but I can still hit VTEC so that is odd. </TD></TR></TABLE>
Old May 3, 2004 | 01:29 PM
99BlackSH's Avatar
I'm quite positive that I am hitting VTEC because it engages at the higher 5k rpm.
I think I'm just going to have to bring it in to the dealership because Someone told me that it could possibly be a leak in the VTEC Filter.
Voodooboy520
Honda S2000
Sep 29, 2008 10:14 AM
poppypizza
Sep 2, 2006 03:41 PM
turnsignalandy
13
Apr 17, 2006 12:26 AM
markpsu227
Jan 5, 2005 11:50 AM
DissidentCivic
30
Jan 14, 2004 03:59 PM
