NA Engine Build ?
Old Apr 27, 2004 | 09:37 AM
ranta18's Avatar
Default NA Engine Build ?
Can you double check my math on these main bearings. This is for a 95 H22 race built NA motor. Here are the specs that were measured. The numbers are averaged out as the bore in the block/cap was a little out of round. The crank was within .0002.
Crank Journal
#1 1.9680
#2 1.9680
#3 1.9679
#4 1.9680
#5 1.9681
Block Bore
#1 2.1269
#2 2.1269
#3 2.1268
#4 2.1276
#5 2.1271
The oil clearance specs I found in my Honda manual are:
#1 .0008-.0018
#2 .0008-.0018
#3 .0010-.0020
#4 .0005-.0015
#5 .0004-.0013
The stamp on my block is 3,3,2,3,3. The stamp on my crank is 3,4,4,4,5. By using the Honda manual, it says to use gr/gr, gr/br, gr/gr, gr/br, br/br.
How loose should I go? I thought it was wierd how small the #4 an #5 oil clearance is compared to the others. If I go by those numbers, the bearing colors for #4 and #5 are way different than the others. Can someone double check the oil clearances.
Old Apr 28, 2004 | 04:43 AM
ranta18's Avatar
Default Re: NA Engine Build ? (ranta18)
Anyone? No one knows the correct oil clearance? Can someone double check this.
Old Apr 28, 2004 | 08:56 AM
junbb1's Avatar
as long as you are using the factory main caps and the original crank you are ok.
no for loosness i would stick to factory clearances. if you are just using it to race with (drag only and trailered) you could step down a bearing size to loosen it up for a **** hair more power.
i dont have the manual in front of me but if you are reading the specs correctly then you will be fine.
Old Apr 28, 2004 | 09:33 AM
ranta18's Avatar
Default Re: NA Engine Build ? (junbb1)
Ok, that didn't answer anything I didn't already know. I guess no one knows and no one has a Honda H22 manual. From talking with Rocket and earl I'm going to run .0018 on all of them.
uberEFtuner
Dec 14, 2014 04:33 PM
turbodcxbro
Jun 23, 2011 05:56 AM
Muckman
May 17, 2004 08:33 PM
ranta18
Apr 27, 2004 02:56 PM
-16V-
Nov 11, 2002 05:35 PM
