water pump ..
Old Apr 27, 2004 | 01:43 PM
abolish415's Avatar
Default water pump ..
i just finished installing my h22a engine on a 92 lude right .. changing the water pump will it be hard to do ??
Old Apr 27, 2004 | 01:46 PM
94svtec's Avatar
Default Re: water pump .. (abolish415)
it would have been a lot easier with the engine out.. but you can do it.. take some time though... to do it correctly.. you will need to remove the driver side motor mount and have the engine supported from underneath. remove the valve cover the timing belt cover.. ETC.. make sure the timing belt is set to the correct timing marks.. it will make installing the belt afterwards alot easier....
Old Apr 27, 2004 | 01:52 PM
abolish415's Avatar
Default Re: water pump .. (94svtec)
haha thanx man .... a lot of help ..!
Old Apr 27, 2004 | 03:16 PM
thehondaguru's Avatar
should have done it out of the car! But just like said before. Its not too bad. Make sure to get a new auto tensioner for the t_belt while your there. Also you really should just change the t-belt
Old Apr 28, 2004 | 08:26 PM
wannabe's Avatar
8-10 hours work with the right tools.
Old Apr 29, 2004 | 08:25 AM
92nb's Avatar
Default Re: water pump .. (wannabe)
8-10 hrs of work? are you kidding me?! Yeah if you're a 2 yr. old. Try 2-3 if you know what you're doing
Old Apr 29, 2004 | 08:32 AM
Sam1am26's Avatar
Default Re: water pump .. (92nb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nb &raquo;</TD></TR><TR><TD CLASS="quote">8-10 hrs of work? are you kidding me?! Yeah if you're a 2 yr. old. Try 2-3 if you know what you're doing</TD></TR></TABLE>
Old Apr 29, 2004 | 08:36 AM
DIE DIE's Avatar
do you guys think it's a good idea to replace the water pump on a JDM h22? I've been told you're suppossed to because it sat for so long.. &gt;?
Old Apr 29, 2004 | 09:50 AM
2.2Euro-R's Avatar
How doe's everyone feel about replacing it with an electric waterpump setup? I think spending around $200 for a potential 5-7 hp gain could be worth it.
vvboy
Jul 5, 2010 11:21 PM
untitled23
Apr 12, 2010 03:08 AM
sir4doorking
Dec 5, 2007 06:12 PM
EGCivicChicago
17
Jan 21, 2007 06:45 AM
Eibach95Civic
Dec 22, 2005 10:05 AM
