what is this sensor
Old May 3, 2004 | 06:56 PM
noble4ws's Avatar
Default what is this sensor
can anyone tell me what 37/38 in this picture are (the whole assembly really) and where do the 3 vaccum lines go, thanks
will change title for search purposes
Old May 3, 2004 | 07:05 PM
LudeyKrus's Avatar
That looks like the goofy-lookin black box that sits near where the stock intake filter is.
I have no clue what the sensor part of it is, though. I may try to check in my Helms later.
Old May 3, 2004 | 07:11 PM
datac99's Avatar
Default Re: what is this sensor (noble4ws)
I'm probably wrong on all counts here, but I'll double check when I get home... I'm assumeing that you must be installing a CAI as all of this gets removed when you do. AEM id's all of this as part of the resonator, I think the vac lines all run to the resonator box (lower left in front of the wheel well) and up into the throttle body. I've pulled the whole mess out when I installed my v2 and everything works just fine.
-PM
Old May 3, 2004 | 07:26 PM
noble4ws's Avatar
ok thanks guys, theres a plug for it and i thought it may be causing my cell, you are right though thats the goofy little black box, thanks
one line goes to the resonator for the butterfly valve on it, another to the intake track before the filter, i dont know where the third goes, and does anybody know what it does?
Modified by noble4ws at 11:55 PM 5/3/2004
Old May 3, 2004 | 08:26 PM
evolvedAP1's Avatar
Default Re: (noble4ws)
what is 25?
Old May 3, 2004 | 11:23 PM
vtecludeh22's Avatar
o think its a vac line that opens a valve flap at higher rpms. but im not sure?
Old May 3, 2004 | 11:34 PM
Fly1865's Avatar
Default Re: (vtecludeh22)
I have part #38 for sell, the sensor. not the black box. let me know
Modified by Fly1865 at 10:57 AM 5/4/2004
Old May 4, 2004 | 04:28 AM
DirtyLude's Avatar
Default Re: (Fly1865)
That's a vacuum solenoid, not a sensor. It's what actually turns the vacuum on and off to open the butterfly valve in the intake resonator. The black box is a vacuum cannister. It's used for vacuum, if the intake doesn't have enough.
There's nothing here that can cause a cel, unless you've disconnected this without tieing off the open vacuum line.
Old May 4, 2004 | 06:09 AM
prelittlelude's Avatar
Default Re: (DirtyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyLude &raquo;</TD></TR><TR><TD CLASS="quote">That's a vacuum solenoid, not a sensor. It's what actually turns the vacuum on and off to open the butterfly valve in the intake resonator. The black box is a vacuum cannister. It's used for vacuum, if the intake doesn't have enough.
There's nothing here that can cause a cel, unless you've disconnected this without tieing off the open vacuum line.</TD></TR></TABLE>
that is correct sir, the box and solinoid open up the longer runner in the resonator to compensate for the increase flow once the secondarys open up and vtec engauges
Old May 4, 2004 | 09:16 AM
DirtyLude's Avatar
Default Re: (prelittlelude)
Actually the resonator valve opens up long before the secondary runners open up.
3000rpm for the intake control, and 4900rpm for the secondary runners. Those are 5th Gen numbers, I believe 4th Gens are slightly different, but not much.
Old May 4, 2004 | 09:51 AM
dr.bushpusher's Avatar
What does it say at the bottom of the page where you looked it up,
just sensor?
jimmyv
Oct 4, 2006 07:41 PM
dingobat
Aug 6, 2006 11:05 PM
thelonerangers
12
Dec 17, 2005 03:37 PM
BB6Driver
Jul 29, 2003 10:23 PM
Nizzy
Jul 20, 2003 08:23 PM
