idle issue
i just recently bought my 92 si, which i noticed had a vacuum leak...so i plugged it up...coming from the cruise control and it died....it won't start as soon as i unplug it, it starts back up...what could be the problem? think ignition timing needs adjustment? or maybe i can set the idle screw higher? sum1 help....thanx
no no...if i plug up the line going into the cruise control....and stop the vacuum leak...it will die....if i pull a vacuum hose from fuel pressure regulator and connect the cruise control it will still run, as a long as there is a vacuum leak...wtf!!!!??? lol...this sux
blockhead428
Apr 7, 2010 12:59 PM
LD_EGSICK
15
Aug 5, 2003 10:35 PM
NeXtLeVeL_TyPe_R
Nov 8, 2001 01:24 PM
NeXtLeVeL_TyPe_R
Nov 8, 2001 11:25 AM
