rev limiter
Old Dec 28, 2004 | 08:59 PM
bseries_beast's Avatar
Default rev limiter
Today i reved my car to like 8 in 2nd gear but it didnt hit a rev limiter. Is that bad? and it felt like it was still pullin after 7500. When do the rev limiters kick in on 5th gens?
Old Dec 28, 2004 | 09:33 PM
luda94's Avatar
Default Re: rev limiter (krazie4vtec)
Every dyno sheet I've seen for preludes without extreme modification shows that power drops off around 7200. As far as a rev limiter, there's no reason you should be revving that high, unless you wanna stretch your rods.
Old Dec 28, 2004 | 09:37 PM
ItalynStylion's Avatar
Sounds like your tach was off...
Old Dec 28, 2004 | 09:50 PM
Speedra500's Avatar
Default Re: rev limiter (ItalynStylion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your tach was off...</TD></TR></TABLE>
right on
Old Dec 28, 2004 | 10:07 PM
5hif7's Avatar
If it was still pulling after 75, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your tach was off...</TD></TR></TABLE>
Also, the limiter is at 82 I believe
Old Dec 29, 2004 | 08:18 AM
DavidT or VajT's Avatar
Default Re: rev limiter (5hif7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5hif7 &raquo;</TD></TR><TR><TD CLASS="quote">If it was still pulling after 75,
Also, the limiter is at 82 I believe</TD></TR></TABLE>
8200
Old Dec 29, 2004 | 12:19 PM
Quick99Si's Avatar
On the tach, yes, maybe 8200rpm depending on how off it is. In real engine speed, 76xx rpm.
Adi
Old Dec 29, 2004 | 12:53 PM
satan_srv's Avatar
Default Re: rev limiter (Quick99Si)
fuel cut is at 7800....not related to what the tach may say. Nail the rev limiter with a V-AFC and have it hold the max...you'll see. Or just take my word for it.
Old Dec 29, 2004 | 01:15 PM
JadedGamerX's Avatar
Default Re: rev limiter (satan_srv)
how dangerous is it to take an h22a4 to rev limit without any modifacations, totally stock 00 SH, I haven't done it just for fear of bending a valve which might have happened on a miss-shift anyway
Old Dec 29, 2004 | 07:11 PM
prylwd's Avatar
Default Re: rev limiter (JadedGamerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX &raquo;</TD></TR><TR><TD CLASS="quote">how dangerous is it to take an h22a4 to rev limit without any modifacations, totally stock 00 SH, I haven't done it just for fear of bending a valve which might have happened on a miss-shift anyway</TD></TR></TABLE>
It would probably be ok but there is no reason to rev that high b/c you wont make any power way up there, so why even chance it. It would be best for you to stay fearful of winding that high.
Old Dec 29, 2004 | 09:07 PM
satan_srv's Avatar
It's not recommended to hit it, but that is what it's there for. Bending valves is when you miss-shift and mechanically the engine has to go above 7800 rpms no matter how much fuel and ignition you cut
Old Dec 30, 2004 | 02:15 PM
Yes well I think I miss-shifted 3 days after I bought the car... it still idles and runs great but the car feels like it has lost a lot of power... I don't know what to do. I hear a lot of ticking from the valve cover but my honda dealership said it was normal. I think they are full of it. Any suggestions? My tools are limited.
EFstyle
26
Jul 26, 2007 04:59 PM
accord03coupe
Honda S2000
17
Mar 27, 2007 03:28 PM
DOHClessEF-9
Nov 21, 2004 06:45 PM
jeff86
Jun 1, 2004 10:56 PM
Behan
May 16, 2003 09:18 AM
