Help with TDC(h22)
Old Jan 3, 2005 | 08:07 PM
blackdelslo's Avatar
Default Help with TDC(h22)
My engine isnt running right and i thought it was because i didnt have everything set to TDC. Right now the arrows on the cam gears are straight up. Now about the bottom end, is the keyway a TDC mark? Meaning do i match the keyway up with the mark on the oil pump? I was told that the key way is not the tdc mark but there is another hard to see mark. plz help. thanks
Im looking through the helms right now but it doesnt specifally say.
Old Jan 3, 2005 | 08:10 PM
Hawkze_2.3's Avatar
Default Re: Help with TDC(h22) (delLudeVTEC)
Pull the little rubber plug on the tranny to see the flywheel timing mark. Right below the upper rad. hose...the Helms should tell you more about it...
Old Jan 3, 2005 | 08:15 PM
Default Re: Help with TDC(h22) (Hawkze_2.3)
Just saw it in the helms, the flywheel mark helps out a lot. thanks
carlosp38
Nov 26, 2007 06:04 AM
bigboostersx
Dec 16, 2004 01:00 PM
4bidden
Mar 13, 2003 09:04 AM
Import RP
Nov 9, 2002 03:49 PM
dallandra
Apr 13, 2002 07:00 PM
