tuneup question
Old Dec 29, 2004 | 10:06 AM
99shRIGGS's Avatar
Default tuneup question
first off, i have a 1999 prelude sh, if sumone could tell me every last piece that is needed for a full fledged tuneup that would be great, im gonna do it myself at school because idont feel like paying the assrape labor at a shopso im gonna buy the stuff and do it myself, secondly...my car bogs a little when i let off the gas and i know that a little bog is sumwhat normal but i have a feeling that this bog is a little bit worse then normal, i know im due for a tune up so if anyone could tell me taht might have sumthing to do with it id be gratefull
o yea and im brand new meat to honda tech so watup everyone
Old Dec 29, 2004 | 10:20 AM
98TypeSH's Avatar
Default Re: tuneup question (99shRIGGS)
Oil, Oil filter, Spark plugs, plug wires, cap, rotor, check condition of break fluid and possible flush and refill. drain and refill tranmission fluid, check clutch fluid and also possible flush and refill. If coolant is old or extremly dirty, also flush and refill. Air filter, check fuel filter, if dirty replace. More things to keep in mind; When was the last time you had your brake pads/rotors checked or replaced? tires rotated? tire pressure checked ?
If this is a major tuneup, otherthings such as; Timing belt, waterpump,and possibly oil pump will need to be replaced. If you are just doing normal **** then what i mentioned above should be sufficent.
Old Dec 29, 2004 | 12:25 PM
Altilude's Avatar
hey man welcome....
also while you have the oil filter off, I'd recommend chucking a new oil cooler o-ring on... they have a tendancy to go when you least expect it, and they're dirt cheap. you'll need a 30mm to get the oil cooler off.
Old Dec 29, 2004 | 03:09 PM
LudaMan's Avatar
Look what I can do!
Default Re: tuneup question (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">Oil, Oil filter, Spark plugs, plug wires, cap, rotor, check condition of break fluid and possible flush and refill. drain and refill tranmission fluid, check clutch fluid and also possible flush and refill. If coolant is old or extremly dirty, also flush and refill. Air filter, check fuel filter, if dirty replace. More things to keep in mind; When was the last time you had your brake pads/rotors checked or replaced? tires rotated? tire pressure checked ?
If this is a major tuneup, otherthings such as; Timing belt, waterpump,and possibly oil pump will need to be replaced. If you are just doing normal **** then what i mentioned above should be sufficent.</TD></TR></TABLE>
stated perfectly right here. Also every time i am under my hood, when i am finishing up, i run a flashlight around and check for leaks.
Also, get yourself a helms manual if you dont have one already.
Old Dec 29, 2004 | 06:50 PM
prylwd's Avatar
Also remember only do what you are skilled enough to do. If you are just learing about this stuff (which I dont know if you are) then I wouldn't jump into changing the timing belt or water pump yourself. Good luck man and wlecome to HT.
Old Jan 7, 2005 | 08:10 AM
99shRIGGS's Avatar
Default Re: (prylwd)
ty u very much all i do it today in school lol i did cap rotor oil oil filter plugs wires fuel filter air filter and a tranny fluid drain and refill...runnin fresh
vietkangta
Jul 28, 2007 12:43 AM
Moshimoto racing
Dec 28, 2005 09:30 PM
RUBZERK
Sep 18, 2003 09:01 AM
migs
Dec 9, 2002 03:38 PM
InfamousRS
Oct 5, 2001 09:55 PM
