ECU problem HELP !
Old Jan 4, 2005 | 06:25 PM
xsoofreshx's Avatar
Default ECU problem HELP !
i jus took my car to my local honda dealership...and they diagnosed my car and told me my ecu is malfunctioning . if i bought a new ecu ...is it easy to replace ? wat tools would i need to do so ?
Old Jan 4, 2005 | 06:48 PM
satan_srv's Avatar
Default Re: ECU problem HELP ! (xsoofreshx)
yeah it's uner the passenger side kick panel you can do it with a 10mm long socket...just unplug the battery first
Old Jan 4, 2005 | 06:51 PM
xsoofreshx's Avatar
damn thanx bro ! honda said its most likely the ecu and wen they tell me its the ecu for sure then im jus gonna tell them ill buy the part and put it on myself...save me couple hundred dollars . they asking 1200 dollars parts and labor...not including the diagnostic fees or watevers .
Old Jan 4, 2005 | 07:02 PM
xsoofreshx's Avatar
is there a aftermarket ecu for 5th gen preludes ? if yes how much and wat kinds are there and wats the best type ?
Old Jan 4, 2005 | 07:22 PM
xsoofreshx's Avatar
if i put in my ecu myself...do i have to reprogram my key ?
Old Jan 4, 2005 | 11:07 PM
Blown90hatcH's Avatar
Default Re: (xsoofreshx)
What year is your lude? You can find ecus online for 50-200 bucks. Don't buy it from honda man that is nuts.
Old Jan 5, 2005 | 06:47 AM
xsoofreshx's Avatar
i have a 98 honda prelude .
Old Jan 5, 2005 | 06:48 AM
What codes are you throwing? Did you take it to tampa hondaland? brandon honda?
Old Jan 5, 2005 | 06:55 AM
xsoofreshx's Avatar
i took it to tampa hondaland...and there was no code...no check engine light either...they went through 5 pages of diagnostic procedures and **** .
Old Jan 5, 2005 | 07:24 AM
satan_srv's Avatar
WHAT IS THE PROBLEM?
You can't just swap an ecu in a 98...the immobilizer has to be reprogrammed.
Old Jan 5, 2005 | 07:33 AM
xsoofreshx's Avatar
ECU IS FRIED !
Old Jan 5, 2005 | 09:35 AM
rjr162's Avatar
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">WHAT IS THE PROBLEM?
You can't just swap an ecu in a 98...the immobilizer has to be reprogrammed.</TD></TR></TABLE>
no no... from my experiences just a week ago (which I believe I am remembering correctly), the ECU needs to be reprogrammed, the Immob unit will be fine as long as he has the keys that match the immob unit. He needs the red key for the immob unit to unlock and reprogram the ECU.
If you get a new ECU and dont' have the keys for the immob unit currently in the car, then you need to get the new immob unit which also comes with a set (1 red and 1 black IIRC) of matching keys that work with the immob unit, and then you use that red key to prorgram the ECU.
I'm just damn glad Honda came out with the T5 keys because all that key matching this matching that stuff is a pain in the ***.
Old Jan 5, 2005 | 01:55 PM
xsoofreshx's Avatar
thanx for ur input bro .
Old Jan 5, 2005 | 02:14 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsoofreshx &raquo;</TD></TR><TR><TD CLASS="quote">ECU IS FRIED !</TD></TR></TABLE>
grrrrr...dude what problem cause you to take the car in and find out from Honda that it is fried? What I am trying to tell you is that maybe it's not fried...I want to knwo what happened..
Old Jan 5, 2005 | 02:22 PM
real_holyfield's Avatar
Since you're replacing the ECU anyway, you could convert to OBD1 and run a P28 with Hondata's piggyback ECU system. Its a fraction of the cost of a standalone engine management system (I'm assuming thats what you were referring to when you said "aftermarket ECU". Check out hondata.com.
Old Jan 5, 2005 | 02:24 PM
xsoofreshx's Avatar
i had my tranny rebuilt 6 months ago...and recently i've been hearing a whinding sound well in SS mode ...so i brought it to my tranny place where they rebuilt it and they told me it was a bearin that had went bad so they replaced it for free since its under there warrantee...but after i got it back i dunno if it was coincidence or wat not...but my fuel cuts off at 68oorpm then my rev limiter kicks in and wont let me pass it....at the same time my vtec didnt feel like it was strong at all...so i brought it back to them and they cant find why its doing that...so i took it to honda and had them look into it and they went throu 5 pages of diagnostic procedures and turns out my ecu is malfunctioning...it need to be replaced...thats the main problem...tomorrow they'll get the new ecu in and raplce it and they're hoping thats the only reason/problem im having and will fix the vtec not hitting hard and fuel cutting off at 6800rpm...ill keep yall updated . thanx for everyones reply .
Old Jan 5, 2005 | 02:27 PM
xsoofreshx's Avatar
Default Re: (real_holyfield)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by real_holyfield &raquo;</TD></TR><TR><TD CLASS="quote">Since you're replacing the ECU anyway, you could convert to OBD1 and run a P28 with Hondata's piggyback ECU system. Its a fraction of the cost of a standalone engine management system (I'm assuming thats what you were referring to when you said "aftermarket ECU". Check out hondata.com.</TD></TR></TABLE>
ya i was referrin to that...but i dunno hondata that well...and i thought this whole time it was a ecu...but it goes connects to the ecu...plus i heard its for onlymauals and mines a auto...i jus had in mind since imma need a new ecu minus well get a aftermarket one..but there really isnt one..so im stick to a new factory one.
Old Jan 5, 2005 | 06:35 PM
rjr162's Avatar
grrrrr...dude what problem cause you to take the car in and find out from Honda that it is fried? What I am trying to tell you is that maybe it's not fried...I want to knwo what happened..</TD></TR></TABLE>
I second this opinion... I was told the same thing... and instead of forking over the $700 to find out if it was it or not (which I'm sure the dealership would not have refunded if it wasn't the ECU even though they were SO SURE it was)... I used my brother's + his immob.. and guess what? Car ran ok for about 15 seconds and started doing the same thing it did with MY computer.
Old Jan 5, 2005 | 08:21 PM
xsoofreshx's Avatar
im not sure..ill kno more by tomorrow ...ill kepp ya updated guys...
Old Jan 5, 2005 | 08:27 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsoofreshx &raquo;</TD></TR><TR><TD CLASS="quote">i had my tranny rebuilt 6 months ago...and recently i've been hearing a whinding sound well in SS mode ...so i brought it to my tranny place where they rebuilt it and they told me it was a bearin that had went bad so they replaced it for free since its under there warrantee...but after i got it back i dunno if it was coincidence or wat not...but my fuel cuts off at 68oorpm then my rev limiter kicks in and wont let me pass it....at the same time my vtec didnt feel like it was strong at all...so i brought it back to them and they cant find why its doing that...so i took it to honda and had them look into it and they went throu 5 pages of diagnostic procedures and turns out my ecu is malfunctioning...it need to be replaced...thats the main problem...tomorrow they'll get the new ecu in and raplce it and they're hoping thats the only reason/problem im having and will fix the vtec not hitting hard and fuel cutting off at 6800rpm...ill keep yall updated . thanx for everyones reply .</TD></TR></TABLE>
it's cutting at 6500...your in ecu safe mode...you are throwing codes or something...is your check engine light not working??
Like when you turn the car on, do you see the check engine light briefly and then it turns off?
Old Jan 5, 2005 | 08:42 PM
xsoofreshx's Avatar
ya they said my ecu light is always on ...whcih is not suppose to...im pretty sure my check engine light works...cuz i threw a code not too long ago...wit my fuel injectors...but i pluged my injectors back in and turned off by itself....now about do i see the light breifly i dun remember looking....they said they cant see to fix the original ecu.
Old Jan 7, 2005 | 08:31 AM
xsoofreshx's Avatar
ttt
Old Jan 7, 2005 | 07:42 PM
xsoofreshx's Avatar
my baby is alive !!! it was the ecu..the replaced it . THE END .
Dasun Perera
Honda Civic (2001 - 2005)
May 4, 2019 07:28 PM
Marcpb443
Acura TSX
May 30, 2012 04:03 PM
ashoka
Oct 24, 2005 07:29 AM
