Odd Technical ghetto question...............
Old Dec 27, 2004 | 04:24 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Odd Technical ghetto question...............
Here's the story. I bought my Girl's 1997 prelude sport shift. The problem is the trans, it's shot and needs a replacement. I wanted to know if I can use the transmission off a F series motor from honda accords in replacement for the H series in Prelude , and will it work correctly. Since I will be using it for daily driving I am not concerned if the Sport shift will work or not just as long as it shifts automatically I'll be fine.
Thanks
Old Dec 27, 2004 | 04:48 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: Odd Technical ghetto question............... (CryBaby X)
bump<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CryBaby X &raquo;</TD></TR><TR><TD CLASS="quote">Here's the story. I bought my Girl's 1997 prelude sport shift. The problem is the trans, it's shot and needs a replacement. I wanted to know if I can use the transmission off a F series motor from honda accords in replacement for the H series in Prelude , and will it work correctly. Since I will be using it for daily driving I am not concerned if the Sport shift will work or not just as long as it shifts automatically I'll be fine.
Thanks </TD></TR></TABLE>
bump
Old Dec 27, 2004 | 05:26 PM
Dougs96SI's Avatar
I dont believe that you can, but i do know that the H22 and H23 are direct replacements for one another, but i dont believe that an F series Transmission will fit along with an H series motor.
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: Odd Technical ghetto question............... (Dougs96SI)
bump ..anyone else?
Old Dec 27, 2004 | 05:30 PM
mgags7's Avatar
no it wont work....physically i doubt it will bolt up....
and you would have a plethora of warning lights and codes...
Old Dec 27, 2004 | 06:00 PM
satan_srv's Avatar
Default Re: (mgags7)
do you realize there's extended warranty coverage for SS transmissions? Check with Honda USA
Old Dec 27, 2004 | 07:12 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">do you realize there's extended warranty coverage for SS transmissions? Check with Honda USA</TD></TR></TABLE>
even on 97's ?
Old Dec 27, 2004 | 07:22 PM
Dougs96SI's Avatar
Default Re: (CryBaby X)
Yeah, most extended warrenties are not done by year, but by milage. Check you warranty and milage of car and see if it can be serviced and repaired.
Old Dec 27, 2004 | 08:27 PM
allmotorteg_96's Avatar
Default Re: (Dougs96SI)
Old Dec 27, 2004 | 09:32 PM
BrokeLude's Avatar
Default Re: (allmotorteg_96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Yeah, what he said...
Old Dec 28, 2004 | 09:06 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: (BrokeLude)
bump anyone else .....
clicky79
Apr 8, 2018 07:20 PM
Ex-Eg-Driver
Jan 7, 2008 10:39 AM
IHateJDM
May 8, 2005 05:48 AM
CALM_AS_A_BOMB
Dec 27, 2004 05:25 PM
cbmprelude
Mar 19, 2004 12:52 PM
