Crower Cams with 37261 stamp...
I'm trying to determine what actual stage cams I have from crower. I've pulled them and they are both (intake and exhaust) stamped "37261" and "Crower". Anybody know?
BTW, Crower's site has nothing w/ this number. All the H22 cams have totally diff numbers...
Re: Crower Cams with 37261 stamp... (Daily Interlude)
its either a ouch or a good thing im thinking. maybe older thats why there not on the site???
Re: Crower Cams with 37261 stamp... (98lude-t)
It could be an older number. This engine has been built for years but only recently been started driven on a regular basis (only like 4-5 K on it).
I've tried searching the net and found nothing...
Anyone know anything about this part number? I've sent them an email so we'll see what happens...
Do you have a set of calipers? It would be nice to know the base circle and the mid lobe lift just be able to compare lobe lift of "modern" Crower H22 cams...
Pirate
Pirate
OK, E37261 is a custom grind (considered a stage 2). Specs are as follows...
Duration @ .050"
Int-234 mid Exh-232 mid
After checking crowers website, they are a notch below a full Stage 2 though probably good for turbo with it's shorter duration...
Duration @ .050"
Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">How about lift? what are those specs? Has this motor been tuned or dynoed? What will the full setup be?
Pirate</TD></TR></TABLE>
Didn't say anything about lift...neither does the site so I didn't think to ask.
No tuning or dyno yet. W/in the next month is probable.
Future plans are to go higher compression, maybe find an aftermarket intake mani, and then get an actual fuel management computer like HOndata. The rest of my mods are located in my sig (My Setup link).
integrawow
07-16-2008 06:01 PM
