install problems/questions
Old Dec 31, 2004 | 12:50 PM
fafsa's Avatar
Default install problems/questions
installed my walbro 255 HP today and the filter provided with the fuel pump when installed didnt look like this
but it was facing the other way, which id have to be careful driving around with low gas. so i reinstalled my stock one that came off my fuel pump, is it ok to re-use? and has anyone else had any problems with it facing the other way forcing u to use the stock one?
Old Dec 31, 2004 | 01:30 PM
Hawkze_2.3's Avatar
Default Re: install problems/questions (fafsa)
I had the same problem at first, but then I flipped the filter around the other way...
Old Dec 31, 2004 | 03:44 PM
fafsa's Avatar
Default Re: install problems/questions (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem at first, but then I flipped the filter around the other way...</TD></TR></TABLE>
you cant really just flip it around can you?? but can you just use the stock filter on the new fuel pump though? do they go bad or something? the oem one looks alot better than the one walbro provides, thanks for the quick responce hawkze
Old Dec 31, 2004 | 03:48 PM
Hawkze_2.3's Avatar
Seriously, I put it back together and it wouldn't fit down in the tank, and then I looked at it for a second, and just flipped it around...
I had a picture of it, but I deleted because I thought I wouldn't use it again
Old Jan 2, 2005 | 09:19 AM
fafsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Seriously, I put it back together and it wouldn't fit down in the tank, and then I looked at it for a second, and just flipped it around...
I had a picture of it, but I deleted because I thought I wouldn't use it again </TD></TR></TABLE>
ahhh damnit! anyone else?
Old Jan 2, 2005 | 11:59 AM
fafsa's Avatar
Old Jan 2, 2005 | 01:49 PM
flip1199's Avatar
it should fit in the tank. you just gotta work at it for a lil bit.
Old Jan 2, 2005 | 06:07 PM
fafsa's Avatar
Default Re: install problems/questions (flip1199)
is it ok to reuse the old filter?
3easy21
Jun 6, 2012 09:21 AM
steveo34609
Apr 11, 2011 07:14 AM
FuNkDrSpOt
Mar 27, 2006 03:41 AM
zman
Mar 5, 2005 12:50 PM
Halo
Feb 11, 2003 10:21 AM
