ignition missing?
Old Jan 3, 2005 | 10:21 AM
98lude-t's Avatar
Default ignition missing?
ok heres what i got. i installed a hyfire6 and accel super coil. just like the msd stuff so i know its fine. well the reason i changed from stock is obviously to have better spark up top. before i changed my car would missfire at 8.5 or so psi only after i changed turbo and exhaust to 3"straight no muff, but also forgot to reinstall the 2nd o2 sensor.
now that i put in the new ignition it misses about 7 psi and at around 6500 in 2nd and others not first it goes to fast not enough boost i think. if i rev it in neutral it doesnt miss on hits revlimit.
is it because i dont have 2nd o2 in or is it my motor having issues { not thinking this one} but possible}. i have stock plugs i changed them to cooler and still did it.
Old Jan 3, 2005 | 10:33 AM
BrokeLude's Avatar
Default Re: ignition missing? (98lude-t)
You sure it's spark and not lack of fuel?
Old Jan 3, 2005 | 10:41 AM
98lude-t's Avatar
Default Re: ignition missing? (BrokeLude)
yeah i uped it to 40% more and it still did it. all it did then was puff out a hella lot of black smoke. i have my water injection also it does it with or without it.
and before with my other turbo i was running 10 psi and no probs then i changed turbo and ran 5 psi no prob then turned up to 8 and then started noticing it.
Old Jan 3, 2005 | 11:26 AM
98lude-t's Avatar
wow no other ideas yet.
Old Jan 3, 2005 | 05:51 PM
98lude-t's Avatar
bump
Old Jan 3, 2005 | 07:39 PM
prylwd's Avatar
That sounds kinda weird. I would also check your timing b/c its fast and easy to check so why not.
Old Jan 6, 2005 | 04:33 PM
98lude-t's Avatar
Default Re: (prylwd)
well no new info. i drove it today and it still does it . ? maybe 2nd o2 maybe im going to put my 21/2 back on and see what the hell. as far as i can see im going to re gap my plugs and see. any thing else anyone can think of.
Old Jan 6, 2005 | 08:17 PM
98lude-t's Avatar
Default Re: (98lude-t)
damn any help im racking my damn brain here no one else can help me.
Old Jan 6, 2005 | 08:42 PM
prylwd's Avatar
Did you check the timing yet?
Old Jan 6, 2005 | 08:52 PM
98lude-t's Avatar
yeah takes a few minutes to check but static timing is on.
Old Jan 6, 2005 | 09:32 PM
98lude-t's Avatar
bumpin
Old Jan 7, 2005 | 07:29 PM
98lude-t's Avatar
well im still needing some ideas?
Old Jan 17, 2005 | 03:28 PM
*Boostwerks*'s Avatar
Hrmmm...Just wondering,
But how do you have the coil mounted? Any pics?
My B18C1 CRX SC61 setup is doing the same thing. I even swapped distributors with no luck. I'm running just a stock distro with an MSD blaster coil
Bryson
victoriasamantha
Mar 19, 2006 04:39 PM
SlammedDC2
Jan 14, 2006 08:44 PM
98lude-t
Jan 7, 2005 10:58 PM
smoothludey2
Jan 7, 2002 08:00 PM
SiRkid
Oct 31, 2001 01:16 PM
