Coolant Flush Step-by-step?
Old Jan 4, 2005 | 06:28 PM
LudeChild's Avatar
Default Someone provide pics
Hello lude dudes. I want to know how to flush the coolant. I am kinna newb at maintaining my car i just do engine changes, spark plug change, and tranny changes myself so if someone can provide me pictures of where the drain bolt is and filler plug or a description of how to flush the coolant and fill you would make my day happy.
Old Jan 4, 2005 | 06:43 PM
satan_srv's Avatar
Default Re: Someone provide pics (LudeChild)
do you have the owners manual? I'm trying to think if it's in there....
and title your threads properly for Christ's sakes
Old Jan 4, 2005 | 08:10 PM
LudaMan's Avatar
Look what I can do!
Default Re: Someone provide pics (satan_srv)
the helms manual has very good directions on how to do it
Old Jan 4, 2005 | 09:14 PM
ludegetsmwet's Avatar
Default Re: Someone provide pics (LudaMan)
how in the world do you know how to change a tranny but don't even know where the drain plug is. sounds like you are just throwing bs and don't know how. i bet your probably looking up how to change your 710 fluid too
Old Jan 5, 2005 | 12:55 PM
LudeChild's Avatar
Default Re: Someone provide pics (ludegetsmwet)
I'm talking about my fluids damaass
Old Jan 5, 2005 | 01:26 PM
shabasoft's Avatar
if by coolant you mean the radiator then there should be a small round plug at eh bottom of the radiator that you can see if you get under the front of the car.
You just need a phillips screwdriver to undo it and all the old liquid will come flying out.
make sure its cold before you do it and undo the cap at the top of the radiator first before doing this.
you can just pull your water tank out and empty it and wash it to get rid of all the dirt at the bottom then fill it up fresh and add anti-freeze/summer coolant..
make sure you put about 2 and a half litres of water into the radiator once you close the plug at the bottom.
hope this helps
goldenreed
Jul 7, 2012 10:55 PM
dk127
Apr 24, 2007 09:01 AM
The Wizard of Lude
Apr 22, 2005 08:24 AM
camera obscura
Jul 13, 2004 06:04 PM
R249
Jan 24, 2003 04:17 AM
