TPS issue.
Old Jan 12, 2013 | 10:46 PM
Sunkenkarma's Avatar
Default TPS issue.
Whats up guys, I have been messing around with my tps trying to get it working for a few days now. I finally got an Multimeter out and tested out the voltage to the tps, Ground/Continuity is perfect, but the yellow and red dont seem to be getting any voltage? I spliced open a little bit of the wire and attach to, and they both are pretty much showing no voltage, I had the key in the "ON" position, and all that good stuff. I can completly unplug the tps, and the car will act no different, so something is iffy here, but I am the worst with wiring, and hoping someone here has some insight.
The car is a 94 prelude S, with an F23a1 swap, Stock ECU (p12 or p13? Whichever is the non vtec, and 3 plugs)
Old Jan 13, 2013 | 12:40 AM
holmesnmanny's Avatar
Default Re: TPS issue.
Check and see if the map sensor is showing the same thing. If so, the ecu could be bad.
Old Jan 13, 2013 | 12:54 AM
1funryd's Avatar
Originally Posted by Sunkenkarma
...The car is a 94 prelude S, with an F23a1 swap, Stock ECU (p12 or p13? Whichever is the non vtec, and 3 plugs)
You do not have a P13, that is for an H22. Double check your ECU code.
Old Jan 13, 2013 | 02:36 AM
Also you should be checking first just the connectors. One will be ground, one will be 4.5-5 volts and one will be signal.
hatchnideas
Mar 9, 2009 05:27 AM
preludecraz
Nov 13, 2008 02:30 PM
traxxasx
Dec 20, 2007 12:03 PM
sicivic
Nov 28, 2005 07:51 PM
