tire sizing....
Old Jan 8, 2013 | 06:43 AM
lilrobie69's Avatar
Default tire sizing....
Ok so my lude is in storage so i dont have the opertunity to check sizing my self so i was wonderin wha u guys are rnnin for wheel and tire sizing. Right now i have 20540r17's but i want more meat on side walls i want 205/50r17 but idk if they would scrape when i turn. Stock came with215/55r16 i belive but the 55 was on a 16" rim. Thnks
Old Jan 8, 2013 | 08:21 AM
fastludeh22's Avatar
Default Re: tire sizing....
How wide are your rims and what is the offset? Also lowered? All will play a factor. Not sure if your aware, but the hight is a ratio to width. Ie 215 or 225/50/17 will not only be wider but taller. I would look into a 215 or 225 to get you more "meat" all around.
I assume your 5th gen based on your stock size which gives you more room then me, but im running 235/60/15 drag radials.
Old Jan 8, 2013 | 08:38 AM
rowe4166's Avatar
i didnt know your could fit 235's on a lude good to know. Thanks
betta285
May 14, 2007 06:10 AM
RA102725
Aug 24, 2006 10:17 AM
civichater
Jul 27, 2004 09:53 AM
nicksweetlude
Dec 10, 2001 07:26 AM
Rain_man
Jun 16, 2001 03:35 PM
