calipers interchangeable?
Old Dec 29, 2012 | 06:22 AM
daveypower's Avatar
Default calipers interchangeable?
Just thought i would ask here first before i go out side and start messing around lol, My 94 jdm si 2.2 F22B dohc preludes brake discs are in need of a serious change, very bad wobbling under braking, these discs are 260mm i belive,
i have a jdm 2.2 si vtec here also, i was wondering would the calipers be a staright swap so i can use the 282mm discs?
Thanks lads.
Old Dec 29, 2012 | 11:30 AM
crazes's Avatar
Moderator
Default Re: calipers interchangeable?
no there are actually different sizes it willnt work correctly
Old Dec 29, 2012 | 02:18 PM
holmesnmanny's Avatar
It might work if you swap over the main bracket.
Old Dec 29, 2012 | 03:02 PM
crazes's Avatar
Moderator
if you do swap you would need to swap the rotors also because different sizes to it also
Old Dec 29, 2012 | 06:24 PM
snobordboy's Avatar
Moderator
Yeah if you have a Vtec model to pull from, just take the calipers, mounting brackets, and rotors all at once. Make sure you are running wheels that will clear them as well.
Old Dec 30, 2012 | 07:07 AM
daveypower's Avatar
nice one man, i have everything there its just im buying new discs (rotors) and id rather buy the 282mm for better braking, plus i will be doing the engine swap come summer so it will save me buying new discs again, the weather over here is horrible to do any work
Old Jan 8, 2013 | 11:11 AM
daveypower's Avatar
Well i went out today and measured things up before i ordered discs and pads, looks like i dont need the carrier, the caliper itself will bolt straight up
Although carriers can be swapped, everything matches up perfect, so ill just swap the calipers probalby.
X01Michael
Dec 10, 2010 08:38 PM
DOHCMonster410
May 26, 2009 09:06 PM
93sivtec
Jan 12, 2007 09:20 AM
dartdc97
Oct 10, 2006 12:05 PM
drSquish
Jul 18, 2006 09:22 AM
