which ECU ?!
Old Mar 13, 2007 | 05:24 AM
smeck's Avatar
Default which ECU ?! (weird errors)
I just swapped my 2.0 for a jdm 2.2vtec (obd2=>obd2) and had no problems the first few hundred miles, but after i stopped for some lunch after a few days i suddenly got the error codes 7 and 30. and I noticed the rpm would automaticaly go to 2000, even when I braked to 1000rpm it would just go up again, so I can acually shift from 1 to 2 to 3 without even touching the throttle. So my first guess is that I have a auto ecu with a manual transmission. but I can't explain why the errors only showed up after about 300miles
ecu code is:
37820-P5M-N51
079-101800
anyone have any idea what might be going on?
Old Mar 13, 2007 | 05:30 AM
BB2H22's Avatar
Yeah, thats an auto ECU. The N51 shows that its auto. That has to be a number less than 50 to be manual. Usually starts with 00. As far as it just now happening, you've got me on that one.
Old Mar 13, 2007 | 05:44 AM
kulrevon's Avatar
Default Re: (BB2H22)
I would say see if you can reset it an drive a while longer while you try to find a manual ecu.
Old Mar 13, 2007 | 05:49 AM
smeck's Avatar
Default Re: (kulrevon)
think i'll just convert it to a manual, there's a sweet write-up here on h-t which uses a p5m as an example so that shouldn't form any problem
Old Mar 13, 2007 | 02:36 PM
alphajesse's Avatar
Doing the jumper swap to convert it to manual is the way to go.
Fook_me_honda
Jan 9, 2008 11:58 PM
Nomac5
Jul 13, 2006 08:09 PM
MugenDC4
Jul 25, 2004 10:47 PM
DC 2
Jan 24, 2004 08:18 PM
Timmayeg
Dec 3, 2002 10:19 PM
