stuck throttle.. bad motor mounts??
okay, a couple weeks ago i knocked out my front motor mount in a 1 to 2 shift.. it rocked the motor pretty hard and kinked my throttle cable.. i got a new one from this shop, and now i think its happened again. my intake manifold keeps mashing my throttle cable into my master cylinder (i think thats what it is, the big circular dish on the driver side firewall).. of which, now, that is also dented (how bad is that, can i keep using it?) .. but. this has happened twice, and i bet it will again.. is this due to a bad rear mount?
If not, what can I do to keep this from happening every week
Re: stuck throttle.. bad motor mounts?? (jdmlude5)
well i didnt BLOW it per se. just the bolts on it backed their way out. I re used all the mounts, and got the new cable.
is there one mount better then the other since i'm going to replace it?
Re: (TylerC161)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TylerC161 »</TD></TR><TR><TD CLASS="quote">So the energy inserts go in use with the stock mounts?
Where can I buy these</TD></TR></TABLE>
Yes, Energy claims they will work fine even with busted OEM mounts.
You can buy it from Summit, Ebay, etc.
http://www.energysuspensionparts.com/
http://www.energysuspension.com/
Canadian_EF
04-07-2013 02:39 PM
blaak-crx
04-23-2008 09:02 PM
elmalouno
06-29-2003 10:27 PM
