Compression test.
Old Mar 4, 2007 | 06:29 PM
zirac50's Avatar
Default Compression test.
I did compression test on my 99 prelude and not sure about the result. c1=130, c2=90, c3=150, c4=145. when i did this I only turn the motor three counts, enginge cold and throttle is closed. This is my first time doing this and not sure if throttle has to be WOT. MY plugs are kinda black little red only on electrode. When i pulled out the compression tester after test ii had some oil in the end. Is that normal? So, my next step was to pull out fuel injector connector while engine is running. When i Pulled out each connector on each cylinder it had some effect (like it lows the rpm more) however, on cylinder 2 fuel inj. conn. when i pulled out it had no reaction. The reason i did this test is that I have CEL lit and code say random misfire so decided to check fuel system.
Do you guys think that a bad injector on C2 causes this really off compression test result compared to c1,c3,c4?
How many times i have to turn the motor when doing compression test? some says 3 and some says 5?
I need help guys, give some ideas.. thank you
Old Mar 4, 2007 | 11:42 PM
The Phil's Avatar
Default Re: Compression test. (zirac50)
Bad injectors don't cause bad compression. Bent valves and dead rings do, among other things.
Old Mar 5, 2007 | 10:24 AM
zirac50's Avatar
Default Re: Compression test. (The Phil)
How bout valve clearance u think that would cause low compression?
Old Mar 5, 2007 | 10:36 AM
Speedra500's Avatar
if the valves are too tight it could, I would start off by redoing the test with the fuel injectors disconnected or the fuse for the fuel pump pulled and opening the throttle
Old Mar 5, 2007 | 11:01 AM
zirac50's Avatar
Default Re: Compression test. (Speedra500)
My valve clearance seems like its loose man cuz they knock loud specialy on cylinder 2 when engine is cold. I don't see any leak as well on my car. Are you saying that it is better to take those fule injector connector when doing compression test?
How many time you have to turn the motor over when doing compression test?
When i did mine i dod not open the throttle and only crank the motor 3times, and some says 5 times?
Old Mar 5, 2007 | 11:20 AM
Chuckles99SH's Avatar
Forget the injectors they have absolutly no berring on the results of a compression test. Injectors = fuel delivery Compression = pressure inside your cylinder
If you had oil on the tip of your compression tester that could be a sign of some bad piston rings or bad valve seal both could cause a poor compression reading. Next logical test for your case imo would be a leakdown test preformed by a shop.
Old Mar 5, 2007 | 11:49 AM
zirac50's Avatar
Default Re: Compression test. (Chuckles99SH)
so definitely not the bad c2-inj. causing this low compression? where are the vavle seals located at? do I need to pull the whole head?
Old Mar 5, 2007 | 12:26 PM
jdmlude5
Guest
Posts: n/a
when doing the compression test. the car must be completely warmed up. and u need to do alot more rotations like let the motor spin over like 5 or 6 times.
76 camaro car
Apr 20, 2017 04:47 AM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
GODSPEED33
Dec 22, 2006 06:04 AM
Si_chRis
15
May 26, 2006 08:46 AM
