OBDII - OBD1
OBDII - OBD1
I have a 97 prelude (base) I just swaped in a JDM H23a VTEC (blue top, not frankenstein) I have a USDM P13 with a boomslang jumper harness. It has the OBD2 harness (no crank sensor installed) with a OBD2 dizzy (td77-U four/two prong plugs) I have NO SPARK. How do I wire up the OBD1 Dizzy (Td61-u five/two prong plugs).
Guest
Posts: n/a
Re: OBDII - OBD1 (preludepower420)
u gotta research. i cant remember. i had to do the same thing. mine is a 96. i got skunk 2 obd2 to obd1 adapter.. u can also keep ur car obd2. just take the oil pump of the obd2 motor. and use the obd2 dizz. and keep it obd2.
Re: OBDII - OBD1 (jdmlude5)
I just got finished putting the engine in . I forgot about all this oil pump/distributor stuff when it was on the engine stand .
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludepower420 »</TD></TR><TR><TD CLASS="quote">I just got finished putting the engine in . I forgot about all this oil pump/distributor stuff when it was on the engine stand .</TD></TR></TABLE>
lol i did the exact same thing. didnt even remember when i went to start it. till i looked at my 23 motor. i just figured it would be easyier to just run the wires
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludepower420 »</TD></TR><TR><TD CLASS="quote">thats what im trying to do what do you think is the best way to do it?</TD></TR></TABLE>
i would just change the oil pump. it seems lick the better way. without cutting **** ya o.
Cyphear
07-13-2007 03:58 PM
screen_name
04-22-2006 06:56 PM
