MAP sensor
Old Mar 2, 2007 | 05:27 PM
whitestreak's Avatar
Default MAP sensor
I have had a 01' Prelude of about 8 months now, for the past few months I have been having problems with my car, occasionally it will stall out and throw a code of the MAP sensor. This will happen at idle and at normal driving speeds. I have replaced the MAP sensor once and it didn’t happen for about a month or 2, now it has started doing it again. What would cause the car to throw a map sensor code and stall out? The car also has a VAFC installed if this makes any difference. The only possible cause for this that I have found is a clogged cat., what else could cause this? HELP!
Old Mar 3, 2007 | 05:56 AM
jdmlude5
Guest
Posts: n/a
Default Re: MAP sensor (whitestreak)
not sure but may be your afc, or the afc wiring, when i unpluged my afc when the car was running. it threw a couple codes, map was 1. hope i helped.
zaks1
14
Dec 4, 2012 10:24 AM
si_motor_spt
Sep 9, 2007 12:31 PM
chrysler kid
Sep 28, 2004 07:24 PM
