Rebuilding Engine
Old Mar 10, 2007 | 06:01 PM
tarheelsoldier's Avatar
Default Rebuilding Engine
I just finished rebuilding my engine and i need to know where the #1 cylinder would be on the camshafts. and i need to know where the plug wires go on the distributor. i will have a running H23 Vtec after i finish this part. Thanks for the help.
Old Mar 10, 2007 | 06:29 PM
jdmlude5
Guest
Posts: n/a
Default Re: Rebuilding Engine (tarheelsoldier)
the number 1 cyl is on the timing cover side(at the timing belt) not to sure of the fire order off hand..
Old Mar 10, 2007 | 07:29 PM
Default Re: Rebuilding Engine (jdmlude5)
.. i know where it is... i need to know what the position of the camshafts are... i need to know if the arrows are facing up down or what..... gotta get it ready to fire tomorrow. and i need to know that. oh and i need to know where the plug wires go on the cap. as in.. plug one wire into upper left and two into upper right....
Old Mar 11, 2007 | 12:55 AM
MLBZ521's Avatar
Arrows on the Cam Gears or the Camshafts themselves?? I don't know of arrows on the Cams, but the arrows on the gears should be faced the same way as the other arrows on your timing pieces, up.
Old Mar 11, 2007 | 04:33 AM
jdmlude_dude's Avatar
Default Re: Rebuilding Engine (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">Arrows on the Cam Gears or the Camshafts themselves?? I don't know of arrows on the Cams, but the arrows on the gears should be faced the same way as the other arrows on your timing pieces, up.</TD></TR></TABLE>
he is right, when you put the cam gears on the cams, they will have arrows that will line up with the timing marks on the crank. that will tell you were they go. if you are at tdc on #1, then the cam gear arrows should be straight up.
550whpcivic
Jul 11, 2011 02:39 PM
h23prelude94
Sep 1, 2008 08:59 AM
Powered by VTEC
Jan 25, 2008 01:05 PM
urtz
Nov 29, 2006 10:54 AM
kpringcivic
Oct 23, 2005 11:36 AM
