caliper rebuilding
Old May 10, 2007 | 07:32 AM
lude98SH's Avatar
Default caliper rebuilding
Well i have done this before on other cars however the kit came with two packets of goo that i have no idea what to use it on. Has anyone done this on a honda using the honda oem rebuild kit ?
Old May 10, 2007 | 03:48 PM
InvaderTrax's Avatar
I believe the goo is for greasing up the slider pins
Old May 10, 2007 | 03:52 PM
mgags7's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">I believe the goo is for greasing up the slider pins</TD></TR></TABLE>
They need to be lubed well. Make sure the boots aren't cracked.
Old May 10, 2007 | 06:18 PM
117's Avatar
117
One packet is for the caliper pins, the other is for the piston seal. Don't try to install the pistons dry, you'll tear up the seals. I've rebuilt 2 sets of Prelude calipers and a set of Legend GS calipers without any issues.
Old May 10, 2007 | 06:28 PM
ludeing1's Avatar
Default Re: (117)
this might help you out a bit
Old May 10, 2007 | 07:14 PM
lude98SH's Avatar
Default Re: (ludeing1)
oook that makes sense...i usually used some brake fluid on the piston but if they gave it to me im sure theres a reason for it
Old May 11, 2007 | 04:18 AM
shutta's Avatar
I had to replace the boots/seals in rear prelude calipers a few months ago and let me tell you... that was probably the most pain in th *** thing ive done in a long time... I ended up buying Autozone rebuilt calipers.. if anyone else has done them they know what i'm talking about..
Old May 21, 2007 | 12:44 PM
lude98SH's Avatar
Default Re: (shutta)
well this is for the front which are alot easier.
There are two packets one is pink and the other orange which do i use for which ?
Old Jun 24, 2007 | 08:13 AM
lude98SH's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">One packet is for the caliper pins, the other is for the piston seal. Don't try to install the pistons dry, you'll tear up the seals. I've rebuilt 2 sets of Prelude calipers and a set of Legend GS calipers without any issues. </TD></TR></TABLE>
Ok the pink one is for the dust cover, the orange is for the pins and the clear is for i guess the square cut seal ? And then use brake fluid on the piston itself i guess ??
Modified by lude98SH at 9:39 AM 6/24/2007
Dr Pooface
Sep 25, 2006 04:28 AM
FuNkDrSpOt
Sep 14, 2006 07:29 PM
RineRacing
Apr 11, 2006 02:33 PM
integlspwr2k
15
Aug 11, 2005 07:51 AM
95greenteg
Jul 19, 2005 08:58 AM
