speedometer
Old May 10, 2007 | 06:57 AM
mtg4gen's Avatar
Default speedometer
does anyone know if the speedometer has anything to do with vtec not working????
Old May 10, 2007 | 07:13 AM
jdizzle!
Guest
Posts: n/a
Default Re: speedometer (mtg4gen)
no y0 check your vss
Old May 10, 2007 | 07:53 AM
Lewdin' Incognito's Avatar
So is your speedo busted and you can't hit vtec? One or the other? Check engine light on / throwing codes?
[Number 5] NEED INPUT.
But no; busted speedo will not take away your vtec.
Old May 10, 2007 | 01:07 PM
Cottonwoodz's Avatar
If your VSS is broken, the speedometer will not work and neither will vtec y0.......
Old May 10, 2007 | 02:09 PM
jdizzle!
Guest
Posts: n/a
Default Re: speedometer (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">If your VSS is broken, the speedometer will not work and neither will vtec y0....... </TD></TR></TABLE>
oh, y0!
Old May 11, 2007 | 06:27 AM
mtg4gen's Avatar
Default Re: speedometer (jdizzle!)
the speedo works kinda but it does not read the right speed. and im throwing vtec pressure switch and solenoid code..ive rewired vtec, checked the screen..i have no clue what is wrong, i am stumped. and what is the VSS?
Old May 13, 2007 | 06:14 AM
95preludes1's Avatar
VSS = Vehicle Speed Sensor - it is a sensor with 3 wires coming from it that sits on top of the transmission. The wires are black for ground, black/yellow for power, and orange for signal.
If you take the intake piping out and look directly down onto the transmission - you will see the VSS. It is held on top of the transmission by 2 10mm bolts.
And to answer your question - VTEC does not engage unless the car is over 20mph, so if your speedo is not working your VTEC will not work either. VTEC also works off of engine temperature and RPM as well.
91EF_Si
Jul 4, 2007 09:58 PM
badbeast
Jul 16, 2006 09:45 PM
civicseth
16
May 18, 2005 08:51 PM
veilsides2000
Oct 18, 2004 07:38 AM
b16-turbo1kid
23
Oct 27, 2003 02:04 PM
