Solid cel after swap
Old May 7, 2007 | 06:36 PM
clemsoncb7's Avatar
Default Solid cel after swap
Hey all,
I have been having significant problems with my swap as I just made the thread pertaining to the transmission. Anyways the h22 is running like **** and I have a solid cel. I was told that the harness could be faulty. This is an h22 in a 91 accord. Could the main harness cause misfiring and a solid cel?
Max
Old May 8, 2007 | 06:22 AM
clemsoncb7's Avatar
Default Re: Solid cel after swap (clemsoncb7)
Bump....
Max
Old May 8, 2007 | 09:25 AM
kulrevon's Avatar
so when you check the codes with the jumper wire you get a solid cell?
Old May 8, 2007 | 10:56 AM
BlacktraxGirl's Avatar
a solid cell usually means there is something wrong with the ECU itself or the connection to it. make sure everything is connecting right and soldered not buttconnected. The harness could be bad or it could be just a loose wire.
is the harness obd2 to obd1?
Old May 8, 2007 | 03:31 PM
clemsoncb7's Avatar
Default Re: Solid cel after swap (BlacktraxGirl)
I checked the ecu, there were only two connections altered, but its an obd1, its in a 91 accord....
Max
Old May 8, 2007 | 05:58 PM
you need to convert from obd0 to obd1 probably.
Old May 9, 2007 | 07:23 AM
clemsoncb7's Avatar
A 91 is obd1 I think... Anyways, there are three altered connections from the ecu, the knock sensor, vtec pressure switch, and vtec solenoid...
Max
Old May 9, 2007 | 10:50 AM
djsire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsoncb7 &raquo;</TD></TR><TR><TD CLASS="quote">A 91 is obd1 I think... Max</TD></TR></TABLE>
wrong
Old May 9, 2007 | 12:16 PM
what ecu are you running right now???
Old May 9, 2007 | 12:58 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlacktraxGirl &raquo;</TD></TR><TR><TD CLASS="quote">what ecu are you running right now??? </TD></TR></TABLE>
P13
Max
Old May 9, 2007 | 03:51 PM
your accord is obd0. the ecu is obd1....you need to get an obd0 to obd1 conversion harness and your problem will go away.
Old May 9, 2007 | 03:53 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlacktraxGirl &raquo;</TD></TR><TR><TD CLASS="quote">your accord is obd0. the ecu is obd1....you need to get an obd0 to obd1 conversion harness and your problem will go away. </TD></TR></TABLE>
I intend to just change the entire harness over to OBD1
Max
Old May 9, 2007 | 04:42 PM
Cool....glad to hear!!! glad it was an easy issue too
good luck and enjoy it like i know i would!
dsl77
Aug 12, 2015 02:49 PM
impr323
Oct 5, 2012 09:08 PM
whitehatchguy
Feb 11, 2008 09:44 AM
Hondasaurs
Apr 25, 2003 09:00 AM
KevronsEG
Jan 21, 2003 02:22 PM
