Trans. Help
Old May 8, 2007 | 04:40 PM
96ej8MR's Avatar
Default Trans. Help
So me and my friend are going to be replacing his transmission on his 95 si lude
what all should we buy besides clutch, throw out bearing, new MTF,
any special tools we will need?( besides clutch alignment tool) what size is the axle nut? 30mm or 32mm are all honda axle nuts the same
any processes that help like to take it out of the top bottom or take the engine out... any help on replacing a tranny in this car would be good
thanks
Old May 8, 2007 | 04:49 PM
nonvteclude's Avatar
Default Re: Trans. Help (96ej8MR)
https://honda-tech.com/zerothread?id=907431
the faq's have alot of info
Old May 8, 2007 | 04:52 PM
96ej8MR's Avatar
more help needed answer other questions
Old May 8, 2007 | 05:09 PM
96ej8MR's Avatar
is that the same for the h23 cuz his is h23 not 22
Old May 8, 2007 | 06:29 PM
96ej8MR's Avatar
help
Old May 8, 2007 | 07:08 PM
SteveoBA8's Avatar
Default Re: (96ej8MR)
Spindle nut=36mm
Replace clutch, inspect flywheel/resurface, rear main seal, replace tob, replace axle seals, mtf. Tranny removal and install in a 4th gen is kinda a pita if this will be your 1st one. H23/F22/H23 all use the same transmission case
Old May 8, 2007 | 07:20 PM
petern101's Avatar
Default Re: (SteveoBA8)
i'll say it again, tell your friend to buy a helms and be done with it.
that could pretty much answer all of your questions and then some.
Old May 8, 2007 | 07:22 PM
96ej8MR's Avatar
ive done trannys before on older subarus those are a pain in the a$$
allmotorh23_818
Jul 5, 2011 05:57 AM
shiux
Oct 18, 2009 06:02 PM
REDLUDE4WS
Aug 29, 2008 11:37 AM
yohan
Oct 11, 2004 07:10 AM
xdrrifterr
Feb 22, 2004 02:19 PM
